LNB Question
Old 3 Weeks Ago   #1
My System: none yet, I am planning to learn from this site.
LNB Question
Can LNB's use all of its outputs simultaneously? For example a single LNB with two outputs (Horizontal and Vertical) is connected to a multiswitch, which is connected to two receivers, can one receiver tune in on the Horizontal and one receiver on the Vertical at the same time?
sexydadee is offline   Reply With Quote
Old 3 Weeks Ago   #2
Manic Midlander Moderator
nanochickin's Avatar
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription
You might aswell just use a quad lnb on its own or a quatrro lnb with a multiswitch
Sanity is nothing more than an excuse to be boring
<<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>>
<<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>>
<<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>>
nanochickin is offline   Reply With Quote
Old 3 Weeks Ago   #3
i want to know if all LNB's have this feature where they can use all of their outputs simultaneously. If not, then what do you call LNB's with this feature? Are Dual and Twin LNB's the same? or maybe i meant 22khz instead of the Horizontal/Vertical switching...
i'm very new at this so I have no idea. I have not even handled any of this LNB stuff. Just reading.
Old 3 Weeks Ago   #4
edit: sorry, I meant use the High Band/Low Band simultaneously (not Hori/Verti)
Old 3 Weeks Ago   #5
satelliteman's Avatar
Real name: Paul
Quad LNb: four independently switched ports.
Quattro LNb: four fixed ports for use with a multiswitch.
satelliteman.
An Installers Choice
Follow us on
Old 3 Weeks Ago   #6
so a quad LNB has like a built in multiswitch?
Old 3 Weeks Ago   #7
Real name: Paul
Yes, correct.
Quad, four port and an Octo being eight switched outputs
satelliteman.
Follow us on
Old 2 Weeks Ago   #8
what about in the case of dual and twin? is there a difference between the two?
Old 2 Weeks Ago   #9
rolfw's Avatar
Real name: Rolf
Don't think Dual LNBs are made any more, 1 Horizontal output and one Vertical output, used for multiswitches. Twin LNBs have two identical universal outlets and are now also occasionally called dual LNBs, in fact some people call monobloc LNBs Dual LNBs as well.
Rolf
Old 2 Weeks Ago   #10
lnb
hello,
the only type i have seen was a dual with a c120 setup on a omt.
the feed horn was bolted to the omt to seperate low and high on each.
since you need 2 c120 lnb and 4 lines one type was needed on each flange.
so one bolted was always horz and the other always vert,
today they have one with 4 outputs that bolts to the feedhorn. it all works the same.
ralph
ralphmagno is offline   Reply With Quote
Old 2 Weeks Ago   #11
what do you mean when you say monobloc lnb and universal output? is there an output other than universal?
Old 2 Weeks Ago   #12
My System: Sky HD, Sky Amstrad PVR3, Technomate TM9100, Targa TSR5200, Fortec Star 5100CI Diamond plus half a dozen more
My old analogue multiroom (4 rooms) used two duals and two "mini magic" multiswitches feeding 13 east and 19.2 around the house for many years. One of the duals and both multiswitches still work at over 20 years old and 18 years constant use.
davemurgtroyd is offline   Reply With Quote
Old 2 Weeks Ago   #13
A monobloc lnb is two lnbs in one housing designed to align on two seperate satellites at the same time - I have seen them with 3, 4, 6 and 9(US only) degree seperation (that seperation is the seperation between the orbital positions of the satellites). A universal lnb is one with two standardised switchable local oscillator frequencies (usually but not always 9.75 and 10.6 GHz) which allows a satellite receiver to tune into all the Ku band.
lnb, question
[IMG] code is Off
