No Satellite SignalInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 19-07-2009 Location: south scotland
My System: Sky+ multiroom | Hi all. I have a new problem - last one fixed thanks to your brilliance ![]() Now this is what's occurred. I have a standard (Thomson) Sky box which has been working perfectly. Also a Sky+ which also is fine. I needed to unplug the regular box so I could get a new ceiling in the bedroom - long story, no point here. When I come to plug the box back in, I get "No Satellite Signal is Being Received." I tried plugging in to one of the Sky+ box feeds and no improvement. I looked on these forums and saw things about Default Transponder, LNB and lots of other things I didn't understand. I even bought a new box on Ebay When I use "Services 401 Select" and "New Installation" Signal Strength and quality are both blank. Default transponder is same as Sky+ box as well as other settings - can't remember .Can you give me any advice? What is and where is the LNB? Can I get it replaced or repaired? I would be really pleased if you could help me get 'er indoors off my back - at least about this - so she can start beating me up about something else ![]() Thanks in advance. Howard | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If the Sky+ box is fine it suggests the Thomson is faulty. Thomsons are well known for capacitor failre in the power supply, (as are older Amstrads!) Unplug the Thommo and pop the top off. Have a careful look at the tops of the capacitors in the area areound the power supply and see if any are bulging or leaking. Keep you fingers well away from the circuit boards - some power supplies can give nasty shocks even after they have been disconnected! | ||
| Super Moderator Join Date: 10-12-2004
![]() | I assume you have a quad LNB, the LNB is at the end of the feed arm on the satellite dish, with all the cables coming from it. I'm guessing that you have 2 cables going to your Sky+ receiver and a third cable going to another room, for your Thomson receiver. It's quite easy to diagnose the fault, as you have already partly done, connect the Sky+ receiver to the third cable and if it works you know that the LNB and cable is fine and the problem is with your receiver. | ||
My System: Sky+ multiroom | | ||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Could be dish alignment, have you had some wild weather up there? | ||
| | #6 | ||
I cannot imagine the weather was that different in Southern Scotland to what it was here and well you've heard of flying carpets, well we had flying fences up here yesterday evening so it is not beyond the realms of possibility the dish has moved a tad | ||
| | #7 | ||
| Specialist Contributor Join Date: 05-04-2008 Location: Costa Blanca, Spain
My System: 1.8m PF Dish, most sky and freesat recivers, 80cm on Illusion motor and Dreambox DM7025, TDT | | ||
| | #8 | ||
| | #9 | ||
My System: Sky+ multiroom | Wouldn't the dish alignment affect the Sky+ box in the living room too? That is working perfectly. If as Mickha says "I assume you have a quad LNB", and only 3 of the 4 connections are in use, would it be an idea to have the "faulty" feed led through the currently vacant LNB connection? If this is worth trying, how do I do it? Thanks again Howard. | ||
| | #10 | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Just unscrew from the LNB the connector that is attached to the cable leading to the faulty position. Then screw it onto the spare output. You will have to retract the raincover first: Just grab the LNB body firmly in one hand and push the cover up until the connectors are exposed. | ||
| | #11 | ||
Also, I suggest you get a spare LNB eg from fleabay ........... As yours is failing, it won't hurt to have a spare to minimise downtime if if degrades further. Don't spend more than a tenner! | ||
| | #12 | ||
My System: Sky+ multiroom | Well I managed to get to the LNB and swap the cable to the spare port. No difference. I'll just need to pay some geezer to do it. Hope he's better than the arsehole who fitted the dish in the first place. Broke several roof tiles and then denied that it was him. I hate these people who put themselves out there as experts in their field and then balls things up. | ||
| | #13 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | | ||
| | #14 | |||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | If it is the cable, you might be advised to get him to run a cable from the spare port as well while he is there, that you can then use if you get yet another box or swop an older box for a PVR. Edit: Actually, I'm just guessing the cable goes over the roof: It's possible the tiles got broken anyway, just out of sheer clumsiness? (Incompetence is probably nearer the mark). | |||
| | #15 | ||
My System: Sky+ multiroom | Yes it was simply the fact that he was a clumsy sod. The roof I'm talking about is the utility room roof which he was standing on to fix the dish to the side of the house. The cable goes through the wall to the loft. He slipped down the roof - my wife heard him - a lot of swearing etc. and then denied everything. I called Sky to complain about the broken tiles and then the so-called installer's boss came on the phone to tell me that he would send the same bloke back to replace the tiles 'cos he "was a roofer until a couple of months ago". Anyway, that was two years ago, so we can ![]() I'm expecting a guy this afternoon, so hopefully we'll be up and running by tonight. Thanks for your help, guys. Much appreciated. | ||
| | #16 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | A sad but not uncommon tale of woe. Let's hope all will be well later, though | ||
| satellite, signal |
