Hi!
i told him,before he purchase,but he dont want to belive me,but now he will do
i have for him a old hirschmann 1,86 m,that will do the job also!
the material is diffrent,but i dont know what kind of,the dealer says only it is reinforced plastic!
from polish mabo antennas,i heard,that the surface,will spoiled,after longer use,maybe around 8 years,and the kuband performance,will be then lower and lower,after many years!
some selfmade brands in czech republik when i look on some website are realy cheap,under 100€ for 1,80m,but i dont know,the brand,for cband use should be okay!
