Advice on multi-sat setupInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 23-09-2009 Location: Gloucestershire
My System: Sky HD box, SkyStar 2 TV card in PC. Triax TD78 with off-set bracket and 3 LNB's. Homwbrew AMD 64x2, Windows 7 |
Hi All, just after a little advice before i buy anything else. At the moment i have an ***** 65cm round steel dish. What id like to do is at a quad LNB pointed at 28E and use 2 feeds to run my Sky HD box. Then add an offset bracket to get 19.2E and 13E. Is it better to use a monoblock or 2 LNB's? I would then like to use a Diseqc switch to take a 3rd feed from the 28E quad and the feeds from 19.2 and 13 down one cable to my Sky Star 2 PCI TV card. I presume monoblocks have a 2 way diseqc switch built in, so if i use one of these, does it daisy chain into a 2nd switch with 28E ok? I know the dish size isnt ideal, but its what i have so i'll give it a go, can always get an 80cm is it doesn't work out. Any recommendations on LNB's, brackets and switches? Thanks! | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Monoblocks do not work in Cascade with other DiSEqC switches. You'd be better using single LNBs for 13E and 19E for the arrangement you require. 80cm Dish probably the best idea. | ||
| The Following User Says Thank You to Tivů For This Useful Post: | JamesA (2 Weeks Ago) |
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Hi James, For those three satellites, an ideal setup could consist of a 90cm, offset bracket and 3 x LNb's. This might be of some interest Offset LNB & Monobloc LNb Guide - Pdf | ||
| The Following User Says Thank You to satelliteman For This Useful Post: | JamesA (2 Weeks Ago) |
| Member Join Date: 08-04-2009 Location: Oxford
My System: Sky HD, Sky Amstrad PVR3, Technomate TM9100, Targa TSR5200, Fortec Star 5100CI Diamond plus half a dozen more | A monobloc can be used with a DiSEqC switch - BUT the switch needs to be of the rare (and expensive -around 60 Euro) "option" type (such as the Spaun SUR211) rather than the common "position" type. See here _http://www.spaun.de/?lang=en&modul=products&product=871437 If you have not already got the monobloc then 3 lnbs and standard DiSEqC switchyh is probably the cheaper and easier way to go. | ||
| The Following User Says Thank You to davemurgtroyd For This Useful Post: | JamesA (2 Weeks Ago) |
| | #5 | ||
My System: Sky HD box, SkyStar 2 TV card in PC. Triax TD78 with off-set bracket and 3 LNB's. Homwbrew AMD 64x2, Windows 7 | Thanks guys, very useful. So looks like i'll get a quad LNB to point at 28E and then 2 single ones for the other two sats along with a 4 way switch to feed 3 of them down to the PC. Glad i waited for replys now ![]() Just need to decide if i try it with the 65cm dish, or just bite the bullet and get an 80cm and do a proper job first time ![]() Have to say its great having just the sky feed into the PC, very handy when my daughter only wants to watch Cbeebies | ||
| | #6 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | A 65cm is a little too small for those three satellites with an offset arrangement. Recommend an 80cm minimum | ||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Although a 70cm Raven Gemini will do it, or the Visiosat Bisat 75cm, but then again they are optimised for offset reception. | ||
| | #8 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Oh yes thanks, forgot about those two dish types Rolf. Rounding up to the nearest, lol | ||
| | #9 | ||
My System: Sky HD box, SkyStar 2 TV card in PC. Triax TD78 with off-set bracket and 3 LNB's. Homwbrew AMD 64x2, Windows 7 | Decided to do it proper ![]() Ordered an 80cm triax dish, off set bracket, switch, 1 quad and 2 single lnb's. Cable, connectors and meter are in the shed ready. Judging from the text i just got from the wife its all arrived Any tips? I was thinking it would be best to get the quad set on 28E first, then add the other 2 on the off set one at a time, directly connected to start with. Then once it all looks ok, put the switch in place and set it all up on the pc. Fingers crossed for a dry weekend so i can set it all up! Cheers, James | ||
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I would centre on 19E, then do the flank LNBs after. | ||
| | #11 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | So would I ............. ![]() ![]() (You did say you were "going to do it proper"!) | ||
| | #12 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | You have no real choice but to do the central one first anyway, as you dont know how far along the offset LNBs need to go. Is it a TD78 or TD88? or neither? ( the TD78 is only about 70cm, the TD88 is about 90cm) With the TD88 you can focus the dish between 23.5E and 19E and if you wanted, and still get a good 13E, and the additional 23.5E. | ||
| | #13 | ||
My System: Sky HD box, SkyStar 2 TV card in PC. Triax TD78 with off-set bracket and 3 LNB's. Homwbrew AMD 64x2, Windows 7 | That does make sense really doesn't it, thanks for pointing it out! Robbo, its a TD 78 now i check the box. | ||
| | #14 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | | ||
| | #15 | ||
| Grimm Member Join Date: 08-03-2009 Location: Blackburn, Lancs
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500 | I have done 13e, 19e and 28e on a TD78. Got deacent signal levels. Checked back with the customer a couple of weeks later and they had had no viewing problems. As suggested best to setup on 19e in the centre, then do the offsets. Or as Robbo suggests line up between 19e and 23.5e. | ||
| I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off! | |||
| | #16 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Also take a browse at this LNB offset guide: http://www.satellites.co.uk/satellit...bracket-sm-pdf | ||
| | #17 | ||
My System: Sky HD box, SkyStar 2 TV card in PC. Triax TD78 with off-set bracket and 3 LNB's. Homwbrew AMD 64x2, Windows 7 | Thanks again folks, most useful. Will make up some patch leads tonight and then i'll be up the ladder first thing tomorrow. Will report back and post a few pics when its done. | ||
| | #18 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | | ||
| | #19 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | To make your life a lot easier, you can set all the lnbs up on the ground if you want, then take it up the ladder. Works best if the wall mount and what you put on the ground are both vertical. | ||
| | #20 | ||
My System: Sky HD box, SkyStar 2 TV card in PC. Triax TD78 with off-set bracket and 3 LNB's. Homwbrew AMD 64x2, Windows 7 | Thanks again everyone, spent a fun couple of hours putting my dish in the air. Went pretty well and got a reasonable signal on all the sats at the moment. Will see how it stands up over the next week and do some tweaking if needs be. Pics posted in the members setups forum for your viewing pleasure. Busy playing with ProgDVB now | ||
| advice, multisat, setup |
