13, 19 & 28 - Dish & Quad LNB QuestionsInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 13-12-2003
I would like to receive 13, 19 & 28, in the North of Scotland, and from a previous post, the advice was to go for a Gibertini dish, as I wanted aluminium (or something similarly weather resistant). A few questions:- Is the feed arm & multi LNB bracket on/for Gibertini dishes strong enough to support (potentially) 3 quad LNBs, in all that the Scottish weather can throw at them? I was planning to go for 3 quads, as mentioned above, but wondered about a 6 degree, quad output, monoblock for 13 & 19, with a quad for 28, as this would reduce the number of cable runs from 12 to 8 (is this correct?); would this be a good option? Are there any potential problems with this option, in comparison to using 3 quads? Do the monoblocks include DiSEqC switching in the LNB, rather than using an external switch, and if so, does this mean that it would not work with a quad added into the mix? Can a monoblock and a quad be accommodated by the LNB bracket, as easily as 3 quads?. Finally, what are the current recommendations for LNBs, offering good performance, reliability, and weatherproofing, as per the options outlined above? TIA. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, Yes a monoblock contains a 2-way diseqc switch. Using a monoblock LNB and a quad can be done but it would work out very expensive as you would need the far more expensive diseqc 1.1 or uncommited switches, since you need 4, it would not be a good idea. It is thus best to stick with 3 individual LNBs. When using LNBs on an offset, their performance is not too critical. I have used Sky quads in the past. Not used the gibby multibracket, so no comment. | ||
| The Following User Says Thank You to Robbo For This Useful Post: | seret (2 Weeks Ago) |
| | #3 | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Depends on if the dish is extremely exposed or not but should be ok; lots of adjustment on those offset LNb brackets. Moved thread to dish set up section. | |||
| dish, lnb, quad, questions |
