monoblock and other dish questionInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Join Date: 12-10-2009 Location: southern ireland
My System: Dm 500s, humax 5400, dell 1530 vista, dsl internet |
I have a quad LNB WITH MY S K Y DISH, WITH 2 OUTPUTS CONNECTED TO MY REGULAR S K Y + BOX AND WITH ANOTHER WIRE COMING IN TO MY HOUSE BUT JUST LYING IDLE. I ALSO HAVE a monoblock LNB with switch built in connected to my dreambox on another dish what do I need to connect up the idle s k y wire to my Dreambox so as to have the monoblock and the 28.2e s k y wire all coming into my dreambox. Many Thanks. | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Well, you can't use a standard Monoblock in cascade with another DiSEqC switch, so perhaps your simplest and cheapest option is to use an A/B Isolation Switch. Connect one input to the Monoblock and the other to the 28E feed. Then you can select, at the push of a button on the switch, the 13/19E arrangement you already have or just the 28E feed. | ||
| Member Join Date: 28-08-2005 Location: South East
My System: 1.2 motorised with technomate | There is a way but you would have to ditch the monoblock and replace with 2 single lnbs a feed from each lnb and the third from the sky lnb go into a diseqc 4 way switch and then you configure your dreambor diseqx opt A/B/C/D You always lose signal quality with monoblock lnb's they are the worst invention ever as you cant skew It should not be too expensive as lnbs cheap at 6 pounds and the dual lnb holders are as cheap as 12 pounds | ||
| | #5 | ||
| Member Join Date: 08-04-2009 Location: Oxford
My System: Sky HD, Sky Amstrad PVR3, Technomate TM9100, Targa TSR5200, Fortec Star 5100CI Diamond plus half a dozen more | A monobloc can be used with a DiSEqC switch - BUT the switch needs to be of the rare (and expensive -around 60 Euro) "option" type (such as the Spaun SUR211) rather than the common "position" type. See here _http://www.spaun.de/?lang=en&modul=products&product=871437 | ||
| | #6 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Yes, uncommitted switch. _www.televes.com/hojastecnicas/103169.pdf | ||
| dish, monoblock, question |
