ASTRA 1kr AND ASTRA 2D on same dishInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Real name: toot Join Date: 03-11-2009 Location: lancs
My System: gds 7000 darkbox |
hi guys i have 2 questions Question one i have an 80 cm dish i was wondering if i can get astra 1kr and astra 2d on the same dish i have got 2 universal lnbs Question Two i have a gds 7000 hd reciver (like the darkbox) how can i get both lnbs connected to the same box it only has an input for one lnb | ||
| | #2 | ||||
| satellite lover Real name: Max Join Date: 21-06-2005 Location: Shetland Islands
My System: DM800 with Smargo and Sky UK World+HD option - Toroidal dish with 8 lnb ( 28.2E, 19.2E, 16E, 13E, 9E, 4.8E, 0.8W, 4W) + DM7020s + SkyUK freesat and 120m movable dish with stab rotor and invacom lnb. | You need another dish. Max | ||||
| | #3 | |||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Many folk get 28E, 19E and 13E on an 80cm Dish. | |||
| | #5 | ||
My System: DM800 with Smargo and Sky UK World+HD option - Toroidal dish with 8 lnb ( 28.2E, 19.2E, 16E, 13E, 9E, 4.8E, 0.8W, 4W) + DM7020s + SkyUK freesat and 120m movable dish with stab rotor and invacom lnb. | | ||
| | #6 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | It's a very common and highly successful arrangement in England, not known for rain fade problems. Up where you live might be problematic, though. Loads of recent Threads from folk wanting to do just this. Brackets are easily obtained and fitted. Of course, if you wanted 13E as well, it's best to focus the Dish somewhere around 21.5E, but it really isn't an issue. | ||
| | #7 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | On an 80cm dish,when adjusted optimally you'd get a signal on both satellites stronger than you would get on a standard sky minidish. Focusing the dish somewhere between the two sats work very well, biased towards Astra 19e. | ||
| | #8 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | If you can find an offset bracket, as said will be ok. A decent 60cm is all you require for these two birds. I remember the TAS60 dishes sky supplied just before launch. Consisted of a small arm for mounting the LNb for 28e. | ||
| | #9 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | The Triax multiblock will fit most dishes if turned upside down and use one of the holders to clamp onto the focal one. Sometimes necessary to 'thin' one of the holders though. | ||
| | #10 | |||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription |
![]() Nano | |||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | ||||
| | #11 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yep, those cheap and nasty plastic LNB holder thingys work too. | ||
| | #12 | ||
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Aluminium actually They looked a bit ropey when i got them for a friend so i sprayed them black | ||
| | #13 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Ahh the metal ones, much better. | ||
| | #14 | ||
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Nah your right they are crap ![]() They do the job though, most of the time ![]() Just make sure the lnb on the dish is secure otherwise they will soon go out of line | ||
| 1kr, astra, dish |
