Help me find astra 2Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Member Real name: Philly Join Date: 20-10-2009 Location: MADRID, SPAIN
My System: Gibertini 1.5 Inverto black ultra, quad. Orbitech fta 400s |
Hi folks, O.k i bought a dish off a friend put a new black ultra quad on it pointed it around a bit and hey presto good signal strength adjusted elevation and skew great signal. Problem is i have picked up a whole bunch of German channels although cnn is in english. I have tried to find other satellites but if i go further east i get saudi arabia channels so how far off from my beloved bbc am i. My elevation on the dish is 46 which is not quite right me thinks, i live in madrid post code 28794 if that helps. I would appreciate it if someone could let me know how far east or west i am of from the correct spot also if my elevation is picking up german t.v at 46 what would it need to be for astra 2. Thanks in advance.........Nosmo | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | You probably need a bigger dish for the BBC channels: _http://www.astra2d.com/spain.htm _http://www.astra2d.com/iberia2d.htm suggests over 2m is needed for decent reception of the BBC & other channels! | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Astra 28.2 is four or so degrees lower than Astra 19.2. | ||
My System: Gibertini 1.5 Inverto black ultra, quad. Orbitech fta 400s | when you say lower do you mean i am in the right place but elevation needs to be lower or what??????????????????? | ||
| | #5 | ||
All the satellites that can be viewed from the earth are on what is known as the Clarke curve see picture, thus the elevation is different for different satellites | ||
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | You could at least post the satellitesuk one Topper | ||
| | #7 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | Lower means that you have to slacken off the satellite clamps and point the dish a little lower in the sky. If you look at Topper's diagram you can see why - as you go from one side to the other satellites appear to be arranged in a circular line . | ||
| | #8 | ||
| | #9 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Cheek! No, I drew it, and then customised it for here and there. I have the clean version somewhere. | ||
| | #10 | ||
| | #11 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Here, have this one, just for you. | ||
| | #12 | |||
| Specialist Contributor Join Date: 11-09-2008 Location: 38.5ºN, 0.5ºW
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | The elevation scale on that dish is pretty accurate. Set it at 33º to start with. Go back to where the arabic channels are, badr 4/6, and then move the dish a fraction more to the east. Move it about the width of the LNB. When I've set up multi LNBs in the past for Astra 2 and Arabsat the LNBs are touching so this should give you an idea just how close you are. | |||
| | #13 | ||
Thanks for the good advice. Holy cow batman i think we have it. I have itv 1, BBC 1 not a lot else have i hit the wrong satellite again is this 19.2 or what? i am getting closer any ideas on what i tuned into | ||
| | #14 | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | If you've got ITV and BBC you are definitely on the right Satellite - If they were also on 19.2E there'd be thousands of very happy bunnies out there! | ||
| The Following User Says Thank You to Tivù For This Useful Post: | NOSMO (1 Week Ago) |
| | #15 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | You are on the right satellite... but... to do this properly you are going to need a decent meter. In England with a mini dish anyone or his granny could tune in 28.2E almost blindfolded but here you need to be really accurate. I find on my setup that the threshold of BBC1, ITV1, etc is 2 clicks from the centreline on my 1224 motor. This means the difference between having the satellite nailed and completely no quality is less than 0.25º. | ||
| The Following User Says Thank You to Huevos For This Useful Post: | NOSMO (1 Week Ago) |
| | #16 | ||
So it appears that i have found astra well sort of. i have a good picture on bbc1 good picture on itv but no bbc2 or much else apart from sky channels which are encrypted. After all the hard work and kind advice do i now need to get someone in with a really good meter. How come i get bbc 1 and not 2. Should i fiddle up down right or left or not at all | ||
| | #17 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| | #18 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | Read Embalse's reports from Madrid: Channel Master 1.2 with CM feed horn and Invacom C120 quad LNB, Channel Master 1.8 with Black Ultra quad LNB. Just to sum up, the 1.2 is very flaky for reception of 2D horizontals, but, the 1.8 gets them 24/7. Your dish should perform closer to the 1.8 than the 1.2. The only channels on horizontals but not verticals are: BBC2/3/4, CBBC, CBeebies, Channel 4 and Five. | ||
| | #19 | ||
The problem was with the box it was searching for 19.2 but satellite was pointing at 28.2 gave me itv and bbc1 but told me it was 19.2. I changed the settings to search for 28.2 and the channels came in thick and fast, hundreds. I have tweeked it a little here and a little there and seem to have fairly good signal although bbc1 started to break up last night at around 8 pm ![]() But hey i have managed it with help from you guys, thanks for all the help and advice ![]() I live in Guadalix de la sierra (Madrid) in case anyone lives nearby. One more thing my sustem cost a mere €100 not bad eh.........The guy i got the dish from was told it was too big. Thanks again and if anyone has any ideas how i can improve the setup or add bits pls let me know. | ||
| | #20 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Fantastic! Very good result indeed | ||
| | #21 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | | ||
| | #22 | ||
My System: Gibertini 1.5 Inverto black ultra, quad. Orbitech fta 400s | Could be, i have adjusted it a little today and so far as of 16.50 Madrid time i have good picture on BBC2, Channel 4 and now i get channel 5. No BBC3 0R BBC4. I will wait to see what happens as the night rolls in but it is better than yesterday. Oh yes great signal and picture on the God channel, if nothing else i may yet receive salvation...Amen | ||
| | #23 | |||
They share with CBeebies and CBBC (Same VPIDs and APIDs - It's just the programming and the Channel Ident that changes). So if you've got CBeebies and CBBC, you've got BBC3 and BBC4 (But if you are picky about the labels and either want both or can't be botherd to Edit, just rescan after 19.00z ![]() You're doing better than you thought you were! | |||
| | #24 | ||
My System: Gibertini 1.5m, Jaeger 1224, Vantage x221 TS CI... Fibo 90, Mot-Sat3, Manhattan Plaza XT-M... Satcatcher Excel-TV, Lacuna Mk4 | NOSMO, can you update your system so we can see what receiver you are using. | ||
| | #25 | ||
My System: Gibertini 1.5 Inverto black ultra, quad. Orbitech fta 400s | its an Orbitech fta 400s. (herein lies my problem me thinks)Got it free with dish. Hoping to get better box soon maybe Humax Foxsat Freesat. | ||
| astra |
