Solid Dish Vs Mesh Dish
Old 2 Weeks Ago   #1
cmclean's Avatar
Smile Solid Dish Vs Mesh Dish
I am using a 1.8 mtr offset solid dish, KU band LNB but as I'm at the edge of the footprint, the reception can be marginal in poor weather. I also have the option to use a 3mtr mesh dish which can be fitted with a KU band LNB. Is there any advantage in using the large dish even though it's mesh rather than solid.
cmclean is offline   Reply With Quote
Old 2 Weeks Ago   #2
doktorofsat's Avatar
My System: C BANDIT
Red face
your location?!
doktorofsat is offline   Reply With Quote
Old 2 Weeks Ago   #3
Satcom1's Avatar
My System: 1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver. Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band.
Though defeated by the evil Fresnel this warrier will return victorious!
If the Mesh is suitable for Ku then there will be an improvement.
Assuming the 3m dish id Prime Focus you will need a proper Ku lnbf.
Go to the Invacom site and study their Ku Scalar feedhorn. A Ku lnbf designed for an offset feed dish will under illuminate your 3m dish.
I am not a complete idiot, some parts are missing.
Satcom1 is offline   Reply With Quote
Old 2 Weeks Ago   #4
cmclean's Avatar
In the caribbean, just on the edge of the footprint for DirecTV. Normally the reception is O.K. but as soon as the weather get's iffy, the picture breaks up.
dish, mesh, solid
[IMG] code is Off
