Help!!!! No hair left
Old 17-08-2002   #1
Pix Meister
pixey's Avatar
If anyone can help I will really appreciate it as i have spent all day trying to tune in my new Humax 5400z receiver. I have my dish set on Thor (I am as certain as I can be) and have the use of a Digisat Pro satellite finder - the signal reading is about 80.
I think I have my receiver set up ok for motorised setup (I am using a v-box and 18" jack). I have gone into the antenna alternative menu, selected Thor from the menu and then done an automatic search. This took anout 3hrs and when it finnished it said 'search completed ok' I pressed the ok button and was back where I started. It doesn't help that the manual is written badly and is quite confusing.
I don't know how to tell the receiver that it is looking at 1w. Channels are preprogrammed into the machine, but I am not sure if they are accurate or not. Is there any way of picking a channel that is on Thor directly? I have been trying to find a 'clear' channel that is listed in What Sat on Thor but to no avail.
If anyone has been through this process I would really apprecaite the help.
pixey
pixey is offline   Reply With Quote
Old 17-08-2002   #2
w hole's Avatar
Hello Pixey
If you don't get a reply here, you could post on this forum which specializes in Humax:
http://groups.yahoo.com/group/humax-users
I know there are quite a few members with 'Z' models.
Mine is only a humble F1_CI so I can't help I'm afraid.
Regards
W.H.
w hole is offline   Reply With Quote
Old 17-08-2002   #3
rolfw's Avatar
Real name: Rolf
Hi Pixey. I've been having box/motor problems today as well, slightly different in nature, but equally frustrating. The frequency to go for is Canal Digital KIOSK 1(Preview Channel) it is always running and always in the clear 11.372 V 24,500 7/8 , as is BBC World, not sure of the frequency.
I would guess from the sound of it you are not on Thor.
Rolf
Old 17-08-2002   #4
auntbeer
Posts: n/a
use prepared settings
my equipment&location:
Germany, Cologne, 60cm dish fixed mounted to thor 1West (pretty good signal level on clear days)
I have used "prepared" settings for finding the right position of thor:
look at
www.humsatsettings.nl (afair they have only the fta channels)
or
www.satcodx.com
export the files at satcodx, and use W. Lizingers "Setedit Oak", which can import satcodx files.
www.setedit.de
as far as i remember, there are also some fta channels at 1 west
another hint:
look at german site ww.satpage.de, there may be some more tips for you
Old 18-08-2002   #5
Post Meister
lee32uk's Avatar
My System: Technomate 1500ci+ super Triax 1.1m dish Diseqc motor Invacom lnb
Do you have access to an analogue receiver ?? If so then you could connect this receiver to the LNB when the dish is at 1deg and check to make sure you are on the right satellite.There is one Analogue channel left on 0.8deg (Thor 2) called TV4 Sweden.
See www.analoguesat.co.uk
I set my system up using Astra1 as a reference point as it is easy to find.The others then fell into place (or most of them )
As for free digital channels then you have Kiosk 1, BBC World,Gospel Channel and a few others.
You can search for channels here www.kingofsat.net
Lee
lee32uk is offline   Reply With Quote
hair, left
[IMG] code is Off
Similar Threads
Transponder update 31/07/03 Satdude Transponders & channels 1 11-08-2005 03:18 AM
Transponder update 26/11/03 Satdude Transponders & channels 0 26-11-2003 02:57 PM
Transponder update 03/10/03 Satdude Transponders & channels 0 03-10-2003 10:44 PM
Transponder update 02/08/03 Satdude Transponders & channels 0 02-08-2003 10:16 PM
Transponder update 03/07/03 Satdude Transponders & channels 0 03-07-2003 01:41 PM
