Receiver won't save Hotbird positionInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. |
Here's an interesting one (To me anyway), just set up the DiseqC motor,using a Zone 2 minidish, good dish, bad adjustment bracket, pulling in Astra, Hotbird, Sirius 5E, Thor and Telecom 2 at 5W at moment. The Hyundai HSS800ci receiver running DiseqC 1.2 is fine and will save and retain positions for all except Hotbird. It finds the satellite fine initially, the save button appears to work, but when i move off to another sat and then try and come back, the moving dish message appears for a while, but nothing is found. Anyone had any similar problems with this or similar receivers, or perhaps has any ideas? Rolf | ||
| Post Meister Join Date: 01-01-2000 Location: Manchester
My System: Technomate 1500ci+ super Triax 1.1m dish Diseqc motor Invacom lnb | I had a similar sort of experience when setting my diseqc motor up.I am using a force 1122s d-master and a cryptik motor.I initially set it up using hotbird as a ref point (as i couldnt find thor).I then got a couple of other locations saved (Astra2,Astra1) but when i chose a channel from 1deg west it went haywire and moved round to about 40deg west.After much hair pulling i decided to reset the motor back to default settings and it seems to be ok now.Not sure if this is just a fluke but it may be worth a go.You shouldnt lose any settings as your dish and mount will be pointing in the right direction from the zero point. Lee | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Done that several times already Lee, doesn't seem to work though, it just seems very odd that it is exclusively on one satellte. | ||
| Rolf You hit on something I noticed with the GBSAT receiver with hard disk which has the same ancestry. The receiver fails to drive back to a previously stored satellite. I spent ages trying to figure out what was happening, and eventually put it down to the difference in protocol required of the DiSEqC motor that was on the roof. Everthing was fine with a Humax VA Fox when it was substituted, so I did not bother to check further into it and resold the GBSat to a fixed dish customer There was a strange method of storing the GBSAT, involving going in and out of menus between satellite and dish limits, further compounded by the supplied software version being erased completely after enabling the factory defauls | ||
| | #5 | |||
| Member Join Date: 01-07-2003
how did you solve a problem ? I´m having simular problem with my Hyundai 825. I cannot save Hispasat is turning always back to Astra. Daniel | |||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I managed to get it working in the end Daniel, but for the life of me I cannot remember how, as I now use the Skystar2 and haven't used the Hyundai for a while. I seem to remember deleting all of the positions and starting from scratch and then it worked, not very scientific, but effective, | ||
| hotbird, position, receiver, save |
Similar Threads | ||||
| 2 dishes: Add 2nd receiver, UHF TV and FM | Artist 2004 | Multi-receiver/TV systems - Domestic only | 8 | 11-03-2007 09:14 PM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| Lidl Satellite Receiver. | spiney | Digital systems | 13 | 28-10-2005 01:15 PM |
| setting hotbird through analogue receiver | gauch21 | Receiver software, international Section | 1 | 24-10-2005 08:45 AM |
| How to find LNB position on Mutifeed holder | xband | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 2 | 04-07-2003 05:12 PM |
