help needed with H-H mount optical sensor
Thread Tools Display Modes
Old 03-07-2004   #1
theslydog's Avatar
I was wondering if anyone knew if u could hook up a Geotrack V-box to a H-H optical sensor in a Jaeger Supermount SMO-36EL?
It looks like the Aston Satseeker DS200 will just hook up to the optical sensor but b4 I fork out the cash for one I was hoping to use the old v-box I already got.
The std ram type actuator has 4 wires 36v +/- and black/grey for the reed sensor GND/Pulse.
The H-H optical sensor has 5 wires 36v+/- and white/yellow/green for GND/Pulses/+5vDC.
Could I run the GND/Pulse from the v-box and find an additional 5v for the mechanical polarizer in the optical sensor to work?
Any ideas?
Pics of all bits
http://www.mondotec.it/ita/prodspics/15428.jpg
http://www.adigitalife.com.au/products/org_135.jpg
http://www.precon.com/sat/positioner...rack_v-box.gif
http://www.precon.com/sat/positioner...ck_v-box_h.gif
__________________
Life's short, go hard, rest when youre dead.
theslydog is offline   Reply With Quote
Old 03-07-2004   #2
Mod and septic resident
Channel Hopper's Avatar
As long as you have a common earth for the return run of the sensor, then a separate 5V supply will be suitable for the optical sensor
The skew output should be OK from the Aston Satseeker, but check that it is a permanent 5V and not one that is only active when the polariser circuit is on . You will need to run the 5V to both actuators
Let me know how you get on , the H to H mount is quite well built, you should get good coverage of inclined orbit satellites from 50W to 50E if correctly set up. Be careful that the canister bolts are not tightened too much on the post otherwise the alloy will crack.
__________________
Channel Hopper is online now   Reply With Quote
Old 04-07-2004   #3
theslydog's Avatar
Thanks for the info Channel Hopper.
Yeah, the Jaeger mount is a big heavy bitch
I have to do a few mods to the dish support ring to be able to properly attach it to the HH mount to set the declination angle.
__________________
[IMG] code is Off
Forum Jump
Similar Threads
Setup the Dish T24 DISH SETUP: Single sat, Multi-Sat & Motorised systems 23 11-05-2008 11:01 PM
Urgently needed for "StarSat SR-X1500D super" problem Ibrahim Samir Receiver software, international Section 13 26-12-2004 03:59 PM
Help needed with My Theatre & DiSEqC switch please davie DISH SETUP: Single sat, Multi-Sat & Motorised systems 9 19-03-2004 07:34 PM
setting up a used H-H mount Sat_Crazy DISH SETUP: Single sat, Multi-Sat & Motorised systems 9 21-02-2004 10:57 PM
Subsidies needed to meet digital deadline net1 Terrestrial Television, Digital and Analogue 0 27-08-2003 06:04 PM
