positioning probs.
Thread Tools Display Modes
Old 17-09-2002   #1
Bram
Posts: n/a
Question positioning probs.
I have a Philips motor and a 180 cm antenna. I have a Nokia and a Philips positioner. Problem: If I mark the satellite as I find them the positioner misses when I go back.
E.g.: Astra is on 365 (position 6) I turn the antenna to watch another sat and then try to go back to 365. It seems like it is working OK, but now Astra is on e.g. 374 so I havve to manually reset the positioner.
Could it be that the wire for steering voltage is too thin??
I have the same problems with both positioners. (Not used at the same time)
Old 17-09-2002   #2
Honorary Admin
2old4this's Avatar
a bad pulse cable can cause noise spikes to be counted as motor pulses (or real motor pulses to be lost). So check your connections, and check that the cables are properly insulated; that there is no rusting/etc.
Might also be play in the motor/actuator itself due to wear&tear.
2old
2old4this is offline   Reply With Quote
Old 18-09-2002   #3
Mod and septic resident
Channel Hopper's Avatar
From a previous life I was led to believe Philips actuators were Optical coupler type position control so only the wear and tear scenario fits the bill.
Philips (actually the Gregorian from Fibo) used a nylon cog which wears out quickly if the dish is able to hit a stationary object or rund over to the fixed mechanical limit about 60 degrees either side of centre. Some companies made a brass copy of the cog and sold it on at wallet depleting amounts. A local lathe operator may be able to make something up thats able to do the job
__________________
Old 18-09-2002   #4
Honorary Admin
2old4this's Avatar
my motor cog is also nylon. It's made in such a way that the cog itself is somehow glued onto a metal spindle. The dish is huge and heavy, and especially at the extremities of its travel, bears heavily on that glue connection. Eventually the glue gave out and it started to slip and all my stat positions were being screwed up. I solved the problem by drilling through the components that were glued, and inserting a metal pin in such a way that they could no longer move relative to each other.
2old
Old 18-09-2002   #5
If only all problems in life were so easy
Im trying to shoehorn a 500cc engine into a 250 bike frame, just for kicks. Im losing the enthusiasm fast and the hacksaw is calling me from the corner of the garage to make the new crank a stressed member
Must resist !
__________________
Old 18-09-2002   #6
Bram
Posts: n/a
positioning probs.
Thanks both of you. I know it is nylon in the cogs. Tomorrow I will
have a peak inside. The slipping cogwheel might just be the thing.
I'll keep you posted.
By the by...
Would anyone know where I can get a manual for my Philips positioner. I only need to know how to save the diff. positions correctly
Old 18-09-2002   #7
rolfw's Avatar
Haave a look at this thread Bram and perhaps PM Jim, the postioner may have similar instructions. Philips D2MAC Receiver FOC
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
Similar Threads
Dragon Cam Probs Alan Pee X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex 1 14-02-2006 12:47 AM
5620 booting probs rogue_element Dreambox5620 10 31-01-2006 11:47 PM
Probs with receiving hotbird.....any ideas please? thewarrior DISH SETUP: Single sat, Multi-Sat & Motorised systems 15 09-08-2005 05:10 PM
probs with sat brad5150 Cards & Programmers General 1 11-08-2004 09:26 PM
Newbie Problem with Motor Positioning Shaun DISH SETUP: Single sat, Multi-Sat & Motorised systems 11 01-11-2002 09:11 AM
