Pixellation/popping at certain times of day on Astra 1
Thread Tools Display Modes
Old 07-09-2004   #1
I wonder if anyone can give me a few pointers which may help me to resolve a problem I have with pixellation and popping noises.
I have an 80cm dish positioned at Hotbird, 13 degrees east. I also have an offset arm with a 0.6db LNB pointed at Astra 1 at 19.2 degrees east. I have an official Irdeto cam and an official Dutch FTV card.
I get perfect reception from everything on Astra 1, with the exception of Ned 1, 2 & 3 which all broadcast on 12515h from Astra 1G. It's totally baffling me! Signal strength is at a guess something like 80-90%. Bleep meter gives me earache when I put that in line it's so strong. I get all the other encypted Dutch FTV channels perfectly (SBS6, RTL 4 & 5 etc etc)...it's just Ned 1, 2 & 3 on 12515h.....and I only seem to have problems with them at certain times of day. Early morning is a prime example. Usually seems ok teatime and evenings. I've tried everything else on Astra 1G...it's perfect.
Can anyone shed any light on what the problem might be, or give me some pointers towards things I could try? It's doing my head in!!!!
Thanks in advance.
moordown66 is offline   Reply With Quote
Old 07-09-2004   #2
Hi M8
I remember reading in the April or May issue of What Sat that in certain area's the new TETRA emergency service cellphone system was being tested and as this system can cause interferance on certain frequencies. but that no publicity as been given to this problem. Do-not remember if you could overcome the problem. Will have a hunt and try to find the article. Can you check with anyone in your area if they also suffer the same problem.
loftyj is offline   Reply With Quote
Old 07-09-2004   #3
rolfw's Avatar
Tetra should not affect satellite transmissions, see http://www.ofcom.org.uk/ind_groups/i...tetra/?a=87101
The problem you are experiencing could possibly be related to a car radar detector, DECT phone, or similar.
__________________
Rolf
Donate
Old 07-10-2004   #4
Just in case anyone is interested, I've found the fault. It's the phone. I've got one of those that sit on a base station, but 9 times out of 10 you just leave it lying around. When it's not sitting on the base station, these channels pixelate. When it's on there, they're fine. Re-createable every time. How about that!!!
Old 04-02-2005   #5
"Satellite Expert"
wolsty's Avatar
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface
The phone's not the cause of my problem. I've recently begun to get pixellation and noises on my Amstrad Digibox on 28 degs. All 'FTA' channels on the old BBC card. No specific time of day. The Hummy works perfectly on the BBC stations, so I suspect a problem in the Digibox. Overheating? PSU? Other?
__________________
wolsty
wolsty is offline   Reply With Quote
Old 04-02-2005   #6
Amo Amas Amant Admin
Topper's Avatar
Smile Update
My Sony Digibox does that when there is a newer version of the software out or there have been channel additions made. I switch it off a the mains socket and let it update itself and after that it is fine. The noises are like a chirp, pop and squeek. Sound like a good name for a breakfast cereal to me.
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 06-02-2005   #7
"Satellite Expert"
wolsty's Avatar
I've done the update, but without success. My attention is now concentrated on the cheapo DVD/home cinema kit I bought a month ago. It seems suspicious that the pixellation first occurred at about the same time. I've now disconnected the dvd and am monitoring the tv.
__________________
wolsty
Old 06-02-2005   #8
"Satellite Expert"
wolsty's Avatar
It's not the DVD setup. Back to Square 1.
__________________
wolsty
Old 11-02-2005   #9
"Satellite Expert"
wolsty's Avatar
I think I may have found the cause. I had a red, white, yellow lead between the digibox and the dvd unit. As I needed only the sound connection, the yellow composite video cable was plugged into the stb, but the other end was left free and was earthing on the case of the dvd unit. I took out the connection and all is well so far.
__________________
wolsty
[IMG] code is Off
Forum Jump
Similar Threads
ASTRA 2D BBC & ITV RECEPTION Expat Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 574 2 Weeks Ago 09:06 PM
Astra 2D + Astra 1 + Hotbird....? xband Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 4 09-11-2003 08:04 PM
Russian Hour on Astra satellites net1 Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 1 14-10-2003 08:03 PM
Astra to launch 1KR in 2005 net1 Transponders & channels 0 09-09-2003 06:26 PM
Astra 1KR & Astra 1L from Lockheed Martin net1 Daily Satellite and Broadcast industry News 0 17-06-2003 09:40 PM
