Strongest / Reference TranspondersInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #26 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | The thread is designed for those who may not be aware which transponders to set on their receiver when aligning their dish, we have had hundreds of posts from members experienceing problems with finding a satellite and very often it is because their receiver has defaulted to an inactive or out of footprint transponder. In an ideal world we would have a list for each of the different areas, as what you can definitely see in Greece, may not be seen from the UK with similar dish size. ![]() We have also endeavoured to find transponders which have FTA offerings where possible and higher symbol rates for more robust reception. | ||
| | #27 | ||
| Thank Me not my Boobs Join Date: 19-12-2002 Location: 47°N/8°E/490m
My System: Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200 | strongest transponders I've added that because my search for the strongest transponders across certain satellites made me have to search more than I should! | ||
| | #28 | ||
| Design Engineer/Installer Join Date: 08-08-2007 Location: Central UK, E Cheshire ..near Jodrell
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... |
STRONGEST TP/ Channels (MID UK 75e-74w KU Band) LIST UPDATE 06/06/08 --------------------------------------------------------------------- These are the strongest Channel/ transponder lists per satellite 75e-74w from the centre of the UK as recorded on one average sample system in mid UK 1.1m Triax/ TMS1000/ Sharp .3 lnbf. 30m cable. Busy in line of sight horizon to horizon limited at 45e 45w plus estimated with a small dish from a vanatage point beyond 45e/w- extreme east estinmated only! Some channels blank but still give signal. ================================================== ========================= SAT_____Freq____H/V______S R____CH Name______________Strength____Quality____NOTES -------------------------------------------------------------------------- 75e_____12548___V_______22000_____________________ _________(v extreme se only) 72e_____12518___V_______2500____E-TV____________________61%_____69%___ se only 70.5e___11214___H_______13021___Euronews 70.5e__________50%_____63%____ 68.5____12562___H_______26657___Press TV________________51%_____66%____ 62e_____11104___H________3328___VTV_______________ ______51%_____65% 60e_____11101___v________4105___Bashkir___________ ______45%_____52%_____?? 57e_____12551___v________9404___BTV_______________ ______52%_____69%_____ 53e_____11616___V________2894___Al Libiya TV____________61%______82%_____ ------------<<<<<-Building/ roof line->>>>>>-----<<<<estimated below 45e- 45e_____11511___v________2894___Southern Sudan T.C._______76%______97%___ 42e_____11804___v_______24444___CNN TURK________________70%______83%_____ 39e_____12524___v_______30000___KAI_______________ ______75%______91%_____ 36e_____12532___h________4340___AZTV______________ ______65%______75%_____ 33e_____11596___v_______27500___MAP TV__________________72%_____85%_____ 28.2e___12460___h_______27500___Portal v 7______________79%_____97%_____ ------------------------ 26e_____12181___h_______16200___SHEBA_____________ ______66%_____86%_____(1st) 26e_____12073___h_______27500___EuroNews__________ ______65%_____83%_____(2nd) 26e_____11862___v_______27500___Arab Tourism____________62%_____80%_____(3rd) ------------------------ 23.5e___11916___h_______27500___TV Rijnnd_______________76%_____97%_____ 21.6e___11530___v_______2857____AL RAI__________________53%_____56%_____<< NEW >> 19.2e___11538___v_______27500___France 26 19e___________74%_____94%_____ 16e_____12540___v_______4340____B.N. Srp________________76%_____92%_____ 13e_____11034___v_______27500___Al Jazeera______________74%_____95%_____ 10e_____11160___h_______2170____Adjara____________ ______69%_____86%_____ 9e______11958___v_______27500___Poker Ch________________75%_____90%_____ 7e______11283___v_______27500___M6 Ssc__________________73%_____88%_____ 5e______12073___h_______27500___Inter+____________ ______74%_____93%_____ 0------------------------------------------------------------------------ .8w_____11229___h_______24500___Poker Channel___________74%_____89%_____ 4w______10722___H_______27500___??________________ ______48%_____50%_____ 5w______11591___v_______20000___France 2________________75%_____92%_____ 7w______11862___v_______27500___City 7__________________51%_____56%_____ 8w______12649___v_______27500___KK________________ ______76%_____91%_____ 11w_____11515___v_______7789____ATV_______________ ______52%_____57%_____ 12.5w___11387___v_______27500___Bethel____________ ______72%_____85%_____ 15w_____12608___h_______19279___MAC TV__________________76%_____95%_____ 18w_____11673___h_______28571___NBA TV__________________69%_____82%_____ 22w_____12735___h_______16640___A3________________ ______72%_____88%_____ 24.5w___11674___v_______27500___Channel S_______________73%_____86%_____ 27.5w___11517___v_______5632____NBA/Intelsat____________72%_____88%_____ 30w_____12012___v_______27500___BBC World 30w___________76%_____93%_____ 31.5w___11504___v_______1600____One TV__________________73%_____84%_____ 34.5w___10969___v_______20000___AV1_______________ ______65%_____75%_____ 43w_____12651___h_______30800___Fox Sports______________69%_____82%_____ 45w_____11510___h_______26894___CCTV 4__________________64%_____74%_____ -----------------------------------------------Building/ roof line------- <<<<estimated below 45w>>>>>> 58w_____11612___h_______3670___Cubavision 58w___________63%____69%_____ ---------------------------------------------------------------------------- | ||
| | #29 | ||
| Member Join Date: 02-07-2005 Location: Essex
My System: 80 x 90cm mesh+DarkGold 0.1Lnb 53 east to 45 west, TM5200D usb super<<A/B>> TM6800HD+, 90 x 100cm Gibertini+MTI 0.3 Lnb>> 45 east to 58 west, TM6900HD Combo Super+<<A/B>>TM1500CI+ Super>>Quali 4:2:2 receiver. |
Strongest transponder's with fta tv Latest update for January 2009 {<<< = new data} East Satellites~~~~~~~FTA where possible~~~~~~~ 45 east IS-12-----------------11500V 4340 Racing International {No fta} 42 ----Turksat 3A------------12679V 8888 24 TV,<<< 40 ----Express AM-1-------11098H 4800 Uzbekistan tv,. 39-----Hellasat-2-------------12523H 30000 The Voice,<<< 36-----Sesat-------------------11639V 2170 Al-Iraqia Atv AF,<<< 33-----Eurobird-3-------------12739V 12402 Zdrave,<<< 31.5---Astra-5A -------------11766H 22000 Astra Vision 31 ----Turksat 1C -----------10994V 2222 Tempo-Turk,<<< 28.5 --Eurobird-1------------11681V 27500 Aljazeera English,<<< 28.2 ---Astra-2D ------------10729V 22000 More 4 UK,<<< 26 -----Badr-4 ----------------12149H 27500 Safa TV,<<< 23.5 ---Astra 1E-------------10862H 22000 Ocko, 21.6 -- Eutel W-6 -----------11531V 2857 Al RAI 1B 19.2 - Astra 1L -------------11597V 22000 BBC World,<<< 16 -----Eutel W-2 -----------12656V 4883 TV Shqiptar Satelit,<<< 13 ---- Hotbird-6 ------------12597V 27500 BBC World News 10 -----Eutel W-1 -----------11160H 2170 Adjara-tv,<<< 9 ------Eurobird-9 -----------11804V 27500 MelodyZen tv,<<< 7 ------Eutel W3A ----------11451V 25066 Digi Turk,<<< 5-------Thor-2 -----------------11247V 23149 Kanal Lokal, 4.8-----Sirius-4 --------------11766H 27500 Novy channel 4 ------Eurobird-4 -----------12539H 39064 data feed,<<< ~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~ West Satellites, 0.8 W --Thor-5 ---------------11785H 28000 1 Music,<<< 0.8 ----Thor-3 -----------------12399H 28000 Musiq1,<<< 1.0 ---- Intel 10-02 ----------12687H 27500 OTV, 4 ------Amos-2 ----------------10757H 27500 MTV Ukraine 5 -----Atlantic-3 ---------------11590V 20000 France 2 7 -----Nilesat 101 ------------11862V 27500 City 7 tv, 8------Atlantic-2 --------------10974V 27500 Al Jazeera English, 11 -----Express 3A -----------{currently there is no active transponder},<<< 12.5 --Atlantic-1 -------------12655H 4285 Record News Int 15 ---Telstar-12 --------------12608H 19279 VOA Persian, 18 ----Intel 901 --------------11569H 5773 A2 Macedonia,<<< 22 ---- NSS-7-----------------11488H 2170 STV-USA 24.5 ---Intel 905 -------------11675V 27500 NTA, 27.5 ---Intel 907 -------------11665V 13020 Five UK {encrypted} 30 ----Hispasat 1C----------12012V 27500 BBC World,<<< 30 ----Hispasat 1D----------11474H 3400 TV Canaria, 31.5 -- Intel 801 ------------{currently there is no active transponder}<<< 34.5 -- Intel 903 ------------11473V 2480 data feed 43.1--- IS-3R ----------------12650H 30800 EWTN, 45.1 ---IS-1R ----------------11510H 26694 CCTV-F, 58 -----IS-9 -------------------11477H 26463 BT Tower A (feeds) | ||
| The Following 5 Users Say Thank You to william For This Useful Post: | imino (08-10-2009), Mostie (14-02-2009), pedro2000uk (31-01-2009), sonic1 (08-03-2009), T_G (27-01-2009) |
| | #30 | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | Thanks william for taking the time to do an update... have you any signal/ quality or meter data. Thanks. | ||
| | #31 | ||
My System: 80 x 90cm mesh+DarkGold 0.1Lnb 53 east to 45 west, TM5200D usb super<<A/B>> TM6800HD+, 90 x 100cm Gibertini+MTI 0.3 Lnb>> 45 east to 58 west, TM6900HD Combo Super+<<A/B>>TM1500CI+ Super>>Quali 4:2:2 receiver. | No but I may include meter readings in the next update in April 2009 after these satellites are fully in service:- Astra 1M for 19.2 east,14 transponders working currently, Hotbird 9 & 10 for 13 east, Eutelsat W2A for 10 east, Express AM44 for 11 west, Telstar 11N for 37.5 west, | ||
| | #32 | ||
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions... | OK, it does help some if they try to get a weak satellite with the wrong dish size. | ||
| | #33 | ||
| Regular Member Join Date: 07-11-2005 Location: Glasgow
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR | Here are my experiences with strongest signals per satellite using my Passion HD box and 90cm dish. Sat Freq Pol S/R Channel Srength Quality 45.0E 11591 V 30000 Discovery 69% 95% 42.0E 11804 V 24444 TNT 68% 100% 40.0E 11096 H 4800 FORUM-TV 71% 83% 39.0E 12729 V 30000 Etno 72% 93% 36.0E 12548 H 2730 Medi1SAT 73% 80% 33.0E 11596 V 27500 MAP TV 70% 85% 31.0E 11012 V 2150 AKSU TV 75% 65% 28.2E Various at 70% / 100% 26.0E 12182 H 16200 YEMEN 71% 61% 23.5E 11914 H 27500 TV Noord 67% 100% 21.6E 11617 V 27500 Radio Euronics 72% 60% 19.2E Various at 70% / 100% 16.0E 11303 V 30000 Foklor TV 69% 92% 13.0E 11200 V 27500 EBC.1 68% 100% 10.0E 12631 V 8888 AP Feed 75% 79% 9.0E 12054 H 27500 Tu Tele Local 69% 90% 7.0E 11451 V 25066 Digi Promo 69% 92% 4.8E 11727 V 27500 TV2 Zulu 70% 60% (Nordic) 4.8E 12418 H 27500 Bookie Feeds 68% 100% (Euro) 4.0E 12536 H 39064 Data 70% 96% 1.0W 12418 V 28000 Poker Channel 68% 100% 5.0W 12543 H 27500 MCM Belgique 70% 98% 8.0W 12649 V 27500 Kabelkiosk 69% 99% 12.5W 11355 H 11781 RAJ CO 74% 74% 15.0W 11060 H 19279 E! EMEA 70% 84% 18.0W 11605 H 8500 Data 75% 75% 22.0W 11563 H 6111 CNN Feed 74% 86% 24.0W 11048 H 14400 TV Agro 73% 86% (DVB-S2) 27.5W 11665 V 13020 Ch5 UK 74% 87% 30.0W 12149 V 27500 Canal 24H 67% 100% 34.5W 11474 V 2480 Data 70% 76% 43.1W 12659 V 28670 Buzz 72% 56% 45.0W 11510 H 26694 CCTV4 71% 66% FYI the Passion locks a signal at 50% quality and gives good rain fade margin at 60%. | ||
| The Following 3 Users Say Thank You to Ratchet For This Useful Post: |
| | #34 | ||
My System: Passion HD, Nova HD S2, 85cm Mesh Dish, Fortec Star Diseqc Motor, Diablo CAM, Sky+ HD, Selfsat H10D2, Hauppauge HD PVR | Update: 33.0E 11093 H 1429 Hayat TV 73% 96% Never seen a signal that strong from 33.0E before. | ||
| The Following User Says Thank You to Ratchet For This Useful Post: | T_G (30-04-2009) |
| | #35 | ||
| Regular Member Real name: Pete Join Date: 13-12-2008 Location: Lower Normandy, France
My System: Gibertini 1M XP Premium - Inverto Black Ultra .2db LNB - Technomate 2200 motor - Vantage 7100 HD. 57E - 22W - 60cm solid oval dish fixed on 28.2 - Humax Freesat HD - Sony Bravia LCD - Sony BluRay and Sony Home Cinema |
Hi, Having recently moved the Triax onto a perfectly vertical pole and tinkered a lot (!)? I now feel confident enough to list the following list, compiled between 15:00 and 17:00 on a clear afternoon: -Pos------TP-------Channel------S/Q 45°E---11618V---Prima--------62/77 42°E---11096V---Powerturk ---69/84 40°E---11097V---UZTV 1-------68/79 39°E---12524H---The Voice----69/84 36°E---12547H---Medi1 Sat----60/81 33°E---11165V---Rete Oro-----65/80 31°E---11009V---Aksu TV------61/68 28.2°E-12207V---Sky News----76/97 26°E---12253H---KTV Ch1------66/59 23.5°E-10863H---Ocko TV------75/96 19.2°E-10818V---TVV Int-------75/96 16°E---11304V---Folklor TV----71/75 13°E---10796V---Tele 5--------73/96 10°E---11747V---BLU----------67/65 -9°E---11804V---C-Music------73/86 -7°E---11345H---TPAI---------69/86 4.8°E--11766H----Novy Ch-----71/85 0.8°W--12418V---Poker Ch-----67/95 -4°W---10759H---Kiev STB-----68/53 -5°W---11591V---France 3-----69/86 -7°W---11862V---City 7--------67/55 --""----12303H----FM----------62/41 -8°W---12649H---Kabel Kiosk--68/88 12.5°W-12720V---Puglia Ch----64/81 -15°W--12608H---BBC Persian-63/72 -22°W--12735H---TV Coran----53/67 24.5°W-11025V---One TV------63/55 ----------------TREE LINE---------- I can get quite a few horizontals on 7W up to 48Q but after 10pm. Still watchable though and most verticals during the day unless it rains!! Hope this is useful, though please remember that I'm a bit further south than the UK in relation to certain footprints. Pete | ||
| Last edited by sonnetpete; 30-04-2009 at 08:53 AM. Reason: Make the list more readable. | |||
| The Following User Says Thank You to sonnetpete For This Useful Post: | T_G (30-04-2009) |
| | #36 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | found these quite good when i was redoing my dish on the west satellites, so add to the current list 18----Intel 901 --------------11605H 8500 data 22 ---- NSS-7-----------------12603H 40000 11563 H 6111 cnn news 24.5 ---Intel 905 --------------11025V 1476 11675V 27500 NTA, | ||
| The Following 3 Users Say Thank You to wod For This Useful Post: |
| | #37 | ||
| Member Join Date: 26-10-2005 Location: Cheshire, UK
My System: Dreambox 500S, Orbital 80cm Dish, Technomate TM-2300 Motor. | My Reference Transponders: NW England. NE Cheshire. These are some excellent transponders found using a dreambox 500s, an 80cm orbital dish, and low noise Golden Interstar lnb. Location: North East Cheshire Sat Freq Pol S/R 42.0E 11804 V 24444 39.0E 12524 V 30000 36.0E 12686 V 04340 33.0E 11513 H 30000 28.5E 11681 V 27500 23.5E 11992 H 27500 19.2E 11597 V 22000 16.0E 11554 V 30000 13.0E 11862 H 27500 7.0E 11513 H 27500 4.8E 12305 H 25547 1.0W 11403 V 24500 | ||
| Last edited by Thundery; 14-08-2009 at 01:13 AM. Reason: Found Stronger Transponder On 28.5E- Previous Post Can be Deleted. | |||
| The Following 2 Users Say Thank You to Thundery For This Useful Post: | CROSSBONES (14-08-2009), T_G (14-08-2009) |
| | #38 | ||
My Reference Transponders: NW England. NE Cheshire. These are some excellent transponders found using a dreambox 500s, an 80cm orbital dish, and low noise Golden Interstar lnb. Location: North East Cheshire Sat Freq Pol S/R 42.0E 11804 V 24444 39.0E 12524 V 30000 36.0E 12686 V 04340 33.0E 11513 H 30000 28.5E 10729 V 22000 23.5E 11992 H 27500 19.2E 11597 V 22000 16.0E 11554 V 30000 13.0E 11862 H 27500 7.0E 11513 H 27500 4.8E 12305 H 25547 1W 11325 H 24500 | ||
| reference, strongest, transponders |
Similar Threads | ||||
| no signal on some transponders | lasharratt | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 06-07-2006 12:24 PM |
| Humax 5400z Reference Satellite | wolsty | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 12 | 25-02-2004 11:54 PM |
| Sesat transponders | Satdude | Transponders & channels | 0 | 28-08-2003 03:22 PM |
| bbc, astra extra transponders | meatball | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 1 | 25-06-2003 10:18 AM |
| Transponders - Some OK - Some not | richardinalex | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 4 | 04-06-2003 02:03 PM |
