Strongest / Reference TranspondersInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh |
I would like to create a list of the strongest transponder for each satellite. When trying to find a sat with a motor is much easier when you know the strongest transponder, and best would be to add to that one or two channels with FTA signal. So, let's have 'em! Important note As this is a sticky thread please do not post questions that are not relevant to this thread. I only want to see lists of transponders of various sats and information that can be used for tuning into a weak signal. All irrelevant posts will be deleted, shreddered and slashed For all other questions there is a whole lot of forum left for it, posting there will make sure you get an answer to your problem | ||
![]() Last edited by T_G; 21-12-2004 at 09:12 PM. | |||
| | #2 | |||
| Super Moderator Join Date: 24-08-2003 Location: Dublin....Ireland
My System: Dusty Dreambox 7000s, & Sky HD. |
| Regular Member Join Date: 09-08-2004 Location: Beds
| I asked the very same question only a few days ago at alt.satellite.tv.europe. I had just received a new receiver and was trying to save myself some time with the tuning. Anyway I've gone through 20+ satellites and these were the strongest transponders for me. I have a motorised 80cm dish with 0.6db lnb. I'm sited in Bedfordshire and use a Finepass twin tuner receiver. Obviously transponder strength will vary depending on location and I do not have every transponder programmed. Here they are: 45e 11.495V 3254 42e 11.135V 4444 39e 12.524V 27500 36e 12.695V 3030 28.2e 10.773H 22000 26e 11.919H 27500 23.5e 11.675H 27500 19e 10.832H 22000 16e 11.554V 28800 13e 10.758V 27500 10e 11.054V 4375 7e 11.175V 27500 5e 11.766H 27500 1w 11.189V 2142 5w 12.543H 27500 8w 11.556H 27500 12.5w 11.132H 3255 15w 11.494V 17464 18w 11.661H 5632 22w 11.613H 1655 27.5w 11.665V 12223 30w 12.012V 27500 | ||
| The Following User Says Thank You to whatpassword For This Useful Post: | postage (29-02-2008) |
| 01LD1E Join Date: 27-07-2004 Location: East of Cambridge (GB).
My System: a variety of lnb's (5), dishes (2), diseqc motors (3) and receivers (4). | A few sats missing that you might like to look for 53E, 11100V, 6000, 3/4 33E, 11472H, 30000, 5/6 4W, 10726H, 3750, 3/4 7W, 11747V, 27500, 3/4 11W, 11464V, 4340, 1/2 37.5W, 12522H, 5425, 1/2 43W, 12584V, 27500, 3/4 45W, 11510H, 26694, 5/6 58W, 11612H, 3670, 3/4 The above is FTA digital transponder information | ||
| | #5 | ||
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Great stuff chaps!! Could you maybe also add to each transponder one FTA channel and details? That way it would be even better, and make it easier for the unexperienced to find the sats. | ||
| | #6 | |||
| Regular Member Join Date: 17-12-2004
| | #7 | ||
Blog Entries: 5 My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | Good work guys, keep it up I west I got 11421 / 241501 H as a very strong transponder. One thing I try is go to the BBC World station at 11342 / 24501 H or to any BBC World on any satellite, they seem to use a fairly strong signal anywhere, as well as being FTA | ||
| | #8 | ||
| I found it yeserday mate, i moved my dish 4 or 5 nudges to the west of Sirus and then manually entered the strongest transponder, i then pulled the rest of the channels in......... all i need now is some new firmware for my xcam - i wish we had AU on conax!!! | ||
| | #9 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed |
Llew | |||
| | #10 | ||
| Archived Member Join Date: 20-12-2004 Location: MYOB
My System: MYOB | Here's my take from NW England: 53E 11044 V 29800 3/4 45E 11627 V 01320 7/8 42E 11812 H 27500 3/4 39E 12524 V 27500 3/4 36E 12686 V 04340 1/2 33E 11472 H 30000 5/6 28E 10744 H 22000 5/6 23E 11475 V 27500 3/4 19E 10773 H 22000 5/6 16E 11554 V 28800 7/8 13E 11862 H 27500 3/4 10E 11607 H 27500 5/6 07E 11471 H 30000 5/6 05E 12303 H 25548 7/8 01W 11421 H 24500 7/8 05W 12543 H 27500 3/4 08W 12649 V 27500 5/6 11W 11483 V 12800 3/4 12W 11345 H 30000 3/4 15W 11494 V 17469 3/4 22W 11675 H 05632 3/4 30W 11811 H 27500 3/4 Now that it's set up, and having played with the motor a bit, I've found it not really necessary to know which is the strongest signal. With my motor, three nudges is equal to one degree. To find a new satellite I just count nudges from the nearest known position and then do a transponder scan. While this is happening I make a note of the transponder with the best signal quality. I change to that one, tweak the position and then scan again. | ||
| | #15 | ||
| Regular Member Join Date: 05-03-2005 Location: The Netherlands
My System: Manhattan Starlight 5900+PVR-80GB,Topfield TF5000CI,Skystar2,110cm dish, Invacom 0,3dB, Moteck SG2100A,range: 75East-61West,AMD Sempron 2600+, Windows XP Pro. | Two more: 68,5 E 12722 V 26657 1/2 Love World 72,0 E 12716 V 2170 3/4 Puglia Channel Jakenl | ||
| | #16 | ||
| Member Join Date: 01-04-2005
My System: Technomate 5500 DAPCI. Sly Box, MM Ver .04+Pentacrypt1.11cam, Conax cam & Dragon cam, Penta VR3 card,MM card, Phoenix Infinty USB Programmer, 1m H-H motorised dish. Panasonic 42" Plasma TV. | @Altis Brilliant & very helpful info. M8 particularly as I live in the Isle of Man Regards Fagela | ||
| | #17 | ||
| Specialist Contributor Join Date: 10-03-2005 Location: Kasaragod,Kerala,South India.
My System: Sat:Insat 4 B and NSS 6 Platform:DD Direct+ STB:Eurobox 9700+CI System:Celeron D 2.8 GHz,Fedora Core 6 and Windows Vista Home Premium Edition. | NSS 6 95 E Indian Beam 12651 V 27500 DD India,DD Sports,Vividh Bharathi Radio (Hindi) 80/98 12732 V 27500 DD Podhigai,MH1,Gyandarshan,DD Bharathi,DD India (Indian Languages) 80/98 | ||
| | #18 | |||
| Member Join Date: 14-05-2005
My System: Echostar 3600 IP Viaccess Dish Nokia 0.85 m LNB Smart Titanium 0.2 dB | Hi, One satellite seems missing: Express AM1 40°E. The strongest signal for me is MKTV 11538 V 3125 Can you please confirm? I'm wondering if Space TV on the same satellite (11159 V 3333) is stronger. Cheers,
| | #19 | ||
| Member Join Date: 02-06-2005 Location: Zaragoza - Spain.
My System: AMD ATHLON XP3000+ ATIRADEON 9600 500MB RAM SKYSTAR 2 DISH 1,2MTS DISH 80cmm LNB INVACOM STAB HH120 MOTOR DM 500+ |
I forgot to put with a valid extension EAST 45,0 E *Europe*1 45*E EUROSTAR 45°E Numer 11.628 V 1.320 7/8 F Numericable M 42,0 E Turksat 1C TURKSAT 42°E 11.805 V 24.444 5/6 F CNN Turk 39,0 E Hellas 1 39°E HELLAS 39°E 12.525 V 27.500 3/4 F ERT sat 36,0 E SesatW4 36°E EUTW4 36°E 12.523 H 4.340 1/2 F LIDER 33,0 E User 3 E-Bird 11.472 H 30.000 5/6 F No Channel 30,5 E User 2 Arabsat 2B 12.620 V 27.500 3/4 F AL-MaidTV 28,0 E Astra2 28°E Astra2 MOT 10.775 H 22.000 5/6 F BBC News 24 26,0 E Arabsat 2A 26°E Arabsat a2 3a 2d 11.862 V 27.500 3/4 F Abu Dhabi 23,5 E Astra3 23°E Astra 3A 12.033 H 27.500 3/4 F Astra TEST 21,5 E User 5 Eutel W1 21¸5ºE User 5 12.726 V 2.170 3/4 F Sicilia Channel 19,2 E Astra 19°E Astra1 MOT 11.779 V 27.500 3/4 F CNN 16,0 E Eutel W2 16°E Eutelsat W2 11.027 H 2.894 3/4 F 7 Gold 13,0 E Hotbird 13°E HOTBRD MOT 11.783 H 27.500 3/4 F TVE i 10,0 E Eutel W1 10°E Eutelsat W1 11.057 V 4.375 5/6 F TgrT 7,0 E Eutel W3 7°E Eutelsat W3 11.177 V 27.500 3/4 F TVP Polonia 5,0 E Sirus 5°E Sirus 2,3 11.768 H 27.500 3/4 F YKPAIHA TPK WEST 1,0 W Intel 707 1°W Thor 2,3 11.190 V 2.142 3/4 F Edusat 4,0 W *Amos1 4°W Amos 1 0 0 0 5,0 W Atl.Bird3 5°W ATLBRD 5°W 12.544 H 27.500 3/4 F GCS Paris 7,0 W *Nilesat 7°W Nilesat 101, 102 12.131 V 27.500 3/4 F Tele Liban 8,0 W Telecom2D 8°W ATLBRD 8ºW PROMO 11.599 H 27.500 3/4 F Kabelvis. Promo 11,0 W Expres 3A 11°W Express 11°W 11.530 V 3.254 2/3 F Comming Soon 12,5 W *Atl.Bird1 12°W ATLBRD 12,5°W 12.515 H 17.455 3/4 F LA7 15,0 W *Telstar2 15°W Telstar 15°W 12.610 H 19.279 2/3 F VOA 18,0 W Intel 705 18°W Intel 705 18°W 11.663 H 5.632 3/4 ? NBA TV 22,0 W NSS 7 21°W NSS7 22°W 11.625 H 3.000 3/4 F Roma UNO 27,5 W Intel 907 27°W Intelsat 27,5°W 11.666 V 12.223 3/4 R FIVE 30,0 W Hispasat 30°W HISPA-30W 11.813 V 27.500 3/4 F TV Galicia 43,0 W *Panamsat6 43°W Panamsat 43°W 12.614 V 1.562 7/8 F Farad Televisa 45,0 W User 1 PAS 1R 45°W 11.511 H 26.694 5/6 F CCTV 4 | ||
| The Following User Says Thank You to cadorna For This Useful Post: | karl121 (24-03-2009) |
| | #21 | ||
| Specialist Contributor Join Date: 19-04-2005 Location: 13°E
My System: DM7020 Screambox MAC OSX & windowzz 98SE Gemini 1664 on tap |
This is great for find the birds. I used it to get a lock on Hispasat. But now I want to fine tune the dish I'd like to know the weakest signal. That way I know I've got 'em all. Is this a daft question ? 1 reply at a time please. | ||
| | #23 | ||
| Regular Member Join Date: 30-04-2004
| ok here is (not necessarily the strongest but ones I do pick up very clear and if ppl remember problems I had with my system it is saying something :-)) (Does help to put location, Swansea, South Wales) will update list when I go through and see which is strongest and weakest. 42E 10.968V 86% strength 69% quality 39E 12.524V 93% / 73% 28.2E 10.803H 97% / 79% 16E 11.449H 96% / 82% 13E 11.131V 93% / 85% 7E 11.491V 94% / 72% 5E 12.073H 95% / 79% 1W 11.420H 93% / 76% 4W 10.743H 87% / 64% (slight breakup) 4W 10.762H 97% / 19% (don't get anything god knows why!) 5W 11.591V 97% / 86% 8W 11.555H 95% / 72% 12.5W 11.389H 86% / 71% 15W 11.150H 92% / 72% 22W 11.630H 85% / 66% 30W 11.731H 94% 72% system is now Lidl crap cable, Technomate 1500CI super, .7dbLNB, Motorise .88m Traix sat dish. | ||
| | #24 | ||
| Specialist Contributor Join Date: 28-06-2004 Location: southern england, Berkshire
My System: Technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky, Span 58W to 42e with trees bare! | 4W 10.762H 97% / 19% (don't get anything god knows why!) The reason you are getting nothing is that its not picking up any signal. The TM 1500 does that often on a Freq where there is no signal and it shows a high signal strenght but it probably is staying red on screen and also giving 19% quality in red also. Theres actually no signal but the TM shows it that way. On the other 4w you also say some slight breakup at 64%. The TM seems to have a threshold of pic/no pic in the low to mid 60's Cheers | ||
| | #25 | ||
| Regular Member Join Date: 20-04-2006 Location: Lost in the night
My System: ? | Is it necessary to know the strongest transpoder for every orbital position? Every orbital position may have several beams. It is there any great difference between the strongest and the weakest transpoder? I don't think that there is any significant difference. Furthermore, if the transpoder is out of order at the installation time? Imagine that there is a heavy rain (or a thick cloud) over the uplink station of the strongest transpoder. How can anyone manage to find the satellite? | ||
| reference, strongest, transponders |
Similar Threads | ||||
| no signal on some transponders | lasharratt | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 06-07-2006 12:24 PM |
| Humax 5400z Reference Satellite | wolsty | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 12 | 25-02-2004 11:54 PM |
| Sesat transponders | Satdude | Transponders & channels | 0 | 28-08-2003 03:22 PM |
| bbc, astra extra transponders | meatball | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 1 | 25-06-2003 10:18 AM |
| Transponders - Some OK - Some not | richardinalex | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 4 | 04-06-2003 02:03 PM |
