Which Motor? | |
| Regular Member Join Date: 19-09-2004
Hello. I am looking to buy a new dish positioning motor and I have seen a couple on Ebay | ||
| A bit enthusiastic Join Date: 11-02-2004 Location: Sweden
My System: Giberini 100,Cut Interstar GI-201,CD-80 feedhorn,Humax 8100 PVR,Coship 2300a,18 meters of Antec Superflex 1.6/7.3 ![]() | Moteck sg-2100 was the testwinner in satcritcs test.Actually I read a post in another forum about a guy using a DG 120 and he had a freeplay of one inch(!) | ||
| | #4 | |||
| Specialist Contributor Join Date: 24-07-2004 Location: Kent
But I think its down to dish size and location mainly, if you live in a very windy location, or have a dish bigger than 1m, you are probably not going to want to use a diseqc motor and would be better getting a specific motor for a specific dish. Its just that the way diseqc motors attach by clamps, which means that they can easily slip out of alignment in strong enough winds. Not happened to me yet thankfully. | |||
| | #5 | |||
I've had a SG-2100 for 10 months now and it's performing very good! | |||
| | #6 | ||
| Thanks everyone for the advice, link and info. The dish I am using (old sat) is slightly oval, 90 in the vertical and 80 horozontaly so I guess its an 85cm. I would expect to move it 3 or 4 times a day. | ||
| | #7 | |||
| | #8 | |||
| | #9 | ||
| Super Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 | The SG2100 is a great value motor IMHO. Having said that, I would rather they come up with a slightly more expensive version, fitted with some decent bronze gearing/bushings (even if that meant jacking up the ratio a bit more). Mine had a little play in it from new, but it's not got any worse. STICK
__________________ | ||
| | #10 | |||
