Technomate 5500 DAPCI analog bugs.
Old 23-10-2004   #1
Hello,
I've recently upgraded my ancient echostar LT-8700 to a technomate TM-5500 DAPCI (that's the one with analog and digital)
Is it normal for the screen overlay (menus, now&next info etc) to be in black and white on analog channels? It makes selecting options linked to the the colour remote butons hard...
I use a se cam to pal transcoder, for the analog French channels on Atlantic bird, which worked fine with the echostar. If I try to use the transcoder with the technomate (by plugging it into the "decoder" scart and setting decoder to "PAL" in the analog search menu for each se cam channel) I get a colour picture but also have a vertical band of flickering black and white "noise" about 1/4 of the way in from the left of the screen and all the video overlay menus also flicker, though the tv picture is stable.
I think this is a video overlay bug, Has anyone else experienced this with the technomate stb? Would switching to a different se cam to pal transcoder help?
I've tried altering the settings under the TV System menu, but to no avail, and the colour adjustment menu isn't avaliable on the analog channels.
If anyone has any suggestions on how to resolve these problems they'd be much appreciated.
regards,
drbob
drbob is online now   Reply With Quote
Old 24-10-2004   #2
hello drbob,
got the same receiver with same problems.
if you fix it let me know.
good luck
jacko is offline   Reply With Quote
Old 24-10-2004   #3
Location: Multi-sat enthusiast in the Heart of England since 1993....
My System: Toshiba 33" CRT TV.. JVC VCR.. Toshiba RD-SX 32 DVD/HDD Recorder..... Sony RDRHXD870 DVD/HDD Recorder.......... Technomate 5500 CI Dap and Technomate TM5400C-usb both connected to a 1.2 metre motorised dish Panasonic 30+90cm dish
sorry that was a double click
JohnC is offline   Reply With Quote
Old 24-10-2004   #4
Like you Ive upgraded from an Echostar SR 8700 and LT8700 to a Technomate TM-5500 DAP CI.... The black and white overlay and no colour control on analogue is normal......
The flickering down the left hand side is related to the Signal Strength/Quality meter that normaly comes up in the bottom left hand corner when you change channels.
This problem usualy shows itself up if a signal is on the weak side...... the fluctuating signal strength constantly triggers the appearence of this information.... hence it strobes down the left hand side... but for some reason it dosnt seem to like Secam no matter what the signal strength is..
I must admit its a darn nuesence.... but one of the charecteristics of the receiver, in my opinion.....
It would be nice if Technomate could introduce an update in the software where-by we could manualy disable the thing altogether if we want to.
Regards John
Old 25-10-2004   #5
This problem usualy shows itself up if a signal is on the weak side...... the fluctuating signal strength constantly triggers the appearence of this information.... hence it strobes down the left hand side... but for some reason it dosnt seem to like S*cam no matter what the signal strength is..
I'm not sure I have the the same problem, the signal is v strong and the constant flickering "noise" isn't just in the bottom left, it's in a vertical bar from the top to the bottom of the screen abround 1/4 of the way in from the left. there is a gap in the "noise" where the channel info/signal strength meter appears. Is this what you see, or just flickering in the bottom left? The overlay menus also flicker but this isn't a big problem as they disappear after a couple of seconds.
regards,
drbob
Old 25-10-2004   #6
Sorry drbob..... I misread your posting........
Ill let you know if I find out more.
All the best John
5500, analog, bugs, dapci, technomate
[IMG] code is Off
Similar Threads
Technomate 5500 dapci Moschino DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 25-11-2004 09:50 PM
Technomate 5500 DAPCI setup maxim DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 19-04-2004 01:30 AM
Technomate 5500 steviewilson DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 28-02-2004 10:40 AM
Technomate DAPCI or Echostar 3600 dutch99 DISH SETUP: Single sat, Multi-Sat & Motorised systems 0 14-02-2004 07:32 PM
technomate tm5000 dapci steve74 Digital systems 3 26-08-2003 11:32 AM
