Actuator / Motor or Multiple LNB's??
Thread Tools Display Modes
Old 28-10-2004   #1
My System: Dreambox DM7000S + 120Gb HDD, 0.8m Dish, Staab H-H Motor. Fortec Star Passion
Question Actuator / Motor or Multiple LNB's??
I need your help and advice on how I should upgrade my system to access more satellites either, with a motor or with multiple LNB's? My funds are limited, budget around 100 pounds....Apologies if this issue has been discussed at length before.
My STB is a dreambox (no 36v output) and my dish is a 1.2m fortec star (heavy at 17kg's). So far I have moved my dish manually which was fun at first but now a pain in the neck! The range of sats I have used to date are 19E, 13E, 1W and 30W.
I could use multiple LNB's and switches for say 19E, 13E, 5E and 1W and could possibly live without 30W??? (Cheap, quick zapping and reliable but limited sat access) or, am I missing some good value viewing on sats I have yet to try with a motor?
My concern is that a Disecq motor may not be durable enough since I am at the extreme of the operating window - 1.2m dia and 17kgs max - I am always surfing the channels so it would be swinging from left to right...every night!
If I was to take the 36v route, funds permitting, I would need a Vbox, polar mount, actuator and replace my cable, not sure I would get approval from higher authorities for such luxury!!!
Obviously you get what you pay for.....so:
Do I buy the LNB's? (Cheapest but restrictive)
Do I buy a Disecq motor (Worried about reliability)
Do I buy 36v System (to be honest too expensive) unless anyone knows of any good deals...
Your feedback will be much appreciated
Samsnake
Samsnake is offline   Reply With Quote
Old 28-10-2004   #2
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
You will get a DiSEqC motor (new) on Ebay for around £40 - £50.
Fit it yourself (if you have a meter - £10) and you should be OK
!.2m dish is at the top end of these motors but I think it would be worth a try.
Just remember to leave the dish at 1 deg west so the wind doesn't catch it ;-)
__________________
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 28-10-2004   #3
BGonaSTICK's Avatar
I know folks do use 1.1M and 1.2M dishes on diseqc motors, but personally I like to operate with a margin of 'safety' and personally wouldn't go over 1.0m.
I think you've talked yourself out of the 36V route based on cost, so there's my recommendation. Multiple LNB's.
You can always add a motor later (when your 'higher authority' is in a good mood! )
To be quite honest, the 36v stuff has fallen from grace a bit based on the ease and simplicity of diseqc, so you might pick up some cheap stuff on Ebay if you're patient.
STICK
__________________
Old 28-10-2004   #4
Location: Multi-sat enthusiast in the Heart of England since 1993....
My System: Toshiba 33" CRT TV.. JVC VCR.. Toshiba RD-SX 32 DVD/HDD Recorder..... Sony RDRHXD870 DVD/HDD Recorder.......... Technomate 5500 CI Dap and Technomate TM5400C-usb both connected to a 1.2 metre motorised dish Panasonic 30+90cm dish
A Motorised system of some sort has got to be the ultimate to achieve your obective in the end...
Adding LNB's has its limitations as Im sure you know.
There are a number of motorised options here>>>....
_http://www.satellitesuperstore.com/motors.htm
JohnC is offline   Reply With Quote
[IMG] code is Off
Forum Jump
Similar Threads
Offset dish LNB:s for fringe reception? steffan_st Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 5 01-03-2004 11:51 AM
Tests on Invacom LNBs geoffreys Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 5 31-10-2003 06:46 AM
Question re. LNBs Leee Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 8 29-10-2003 03:42 PM
Multiple Lnb's on Motorised system ? Rob T DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 04-09-2003 09:18 PM
PLL Lnbs gcohen Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 4 08-07-2003 08:23 PM
