Motor problem
Thread Tools Display Modes
Old 30-10-2004   #1
Motor problem
During last week’s storms, my dish was blown onto the near-by wall. I have manually put it back in the previous position, but I am unable to move it with my disecq motor.
One can hear it trying to move it, but the movement is not happening. I assume therefore that the motor is not burn-out and that the problem might lay elsewhere. The connections are as they were – receiver-motor and motor-lnb.
Any ideas?
berlioz is offline   Reply With Quote
Old 30-10-2004   #2
Nasty Dish Obsession
Lancelot's Avatar
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H
...And thou were the truest friend to thy lover that ever bestrad horse..."
Don't want to sound too pessimistic but -
you may have had your gearing stripped for you.
can you get inside it to take a look ?
L
Lancelot is offline   Reply With Quote
Old 30-10-2004   #3
L
Tanks for replying Lancelot.
I do not dare look inside it, as I would probably make things worse (kill or injure it fatally).
Old 30-10-2004   #4
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
You should look it may just be jammed or the teeth have skipped.
Don't know if you can buy spares but don't see why not!
__________________
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 30-10-2004   #5
Lancelot's Avatar
As Gameboy says - It may be just that the drive has slipped on the shaft
and just needs a gentle tap back into position.
After all it's not moving the dish so what have you got to lose.
Let us know the outcome.
Good luck.
L
Old 14-11-2004   #6
Just an update on my motor problem ... according to the engineer, it cannot be repaired. He took it off, and now I hope that good people of satelliteshop.co.uk will replace it with the new one. Thank you very much for your ideas.
Berlioz
Old 14-11-2004   #7
Lancelot's Avatar
Good Luck with the new install
Old 14-11-2004   #8
Ding Dang Doo
gameboy's Avatar
Hope everything works out and you're back up and running soon.
Are you going to set it up yourself or get the engineer to do it?
Might be worth a try if your mount and dish aren't damaged, did you keep a note of the inclination settings on the old motor?
__________________
Old 14-11-2004   #9
BGonaSTICK's Avatar
Hmmm, somebody could make a fortune out of repairing those suckers. What's the worst that could have happened? As you say, a few stripped teeth and maybe a bent shaft.
Having said that, somebody could make an even bigger fortune out of writing them off as scrap...
Ahhh, a truly disposable society.
__________________
[IMG] code is Off
Forum Jump
