Just Bought A Motor | |
| Specialist Contributor Join Date: 29-07-2003 Location: Chorley, Lancs
My System: Innovative, Diseqc Motor, 80cm dish |
Hi All I have just purchased a JAEGER SUPERJACK DG-120 DISEQC MOTOR to go with my: SkyStar2 PCI DVB BigSat 8000 Deluxe 80cm Dish 0.6db LNB Now i have 2 recievers i wish to connect, obviously only one can control the motor, but how do i connect them all together. cant really use the loop through as the recievers are in different rooms. So do i need a twin lnb and run a 2nd cable or can i split the signal elsewhere? | ||
| As the loopthrough is a single cable, running between rooms should not be impossible, but it is probably better to drive the dish with just one receiver and have a twin LNB on the dish
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #3 | |||
Cheapest i can find on Ebay cheers | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Sounds like good value.
__________________ | |||
Similar Threads | ||||
| Just bought motorised system, help needed to unlock channels for Topfield TF3000cipro | mshabir | Receiver software, international Section | 4 | 25-10-2005 09:03 PM |
| Just bought some stuff! HELP! | znpr | Keys and Key editing | 3 | 16-02-2005 09:56 AM |
| I've bought Dragon Cam and Infinity Programmer today | fearny23 | X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex | 6 | 02-02-2005 12:17 AM |
| Just bought a new receiver - need your views | Ian_ExManchester | Digital systems | 1 | 29-08-2004 11:13 AM |
