Originally Posted by cfphoenix Can I connect the 1.1m triax to one of the unused input of the 4 way diseqc switch? (I want to use the fixed dish with 3 LNBs for 13, 19, 28 and the motorised 1.1 m dish for thor 1w and hispasat 30w).
Is the above possible? Or am I talking furry sheep here? Anyway, I will give it a try and see how it goes. |
Hi Phoenix, I'm heading for virtually the same set up, except I'm planning to rotate my dish with a 36V actuator+Vbox. I asked a similar question to which answers weren't straight and forthcoming.
I haven't set up all my kit so can't comment on what would actually happen.
On an investigative front the other day I checked out the diseqc spec to see just exactly what it would support - and the following is my reasoning: Section 8.2 of the diseqc bus spec (
http://tinyurl.com/44y67 from
http://www.eutelsat.com/satellites/4_5_5.html ) seems to suggest different devices are addressed differently - i.e. you can talk to the switch and motor independently. I bought a 4-way diseqc switch the other day which has cleared hex addr 0x15 printed on it, I'm guessing a diseqc motor might respond to 0x31.
So in theory, if your receiver knew to send commands to the motor down through the '4th' lnb position it could work, however whether the receiver would support such a set up is questionable.
It would have to know to switch to the '4th' lnb position, then send the motor command and know it was looking for another sat.
In my planned setup I've got a bit more leeway since I can put the vbox before or after the switch, and if it plain doesn't work in the world of diseqc I can still use the 4-way switch, but when it comes to choosing 1W or 30W I can point the remote at the vbox to twist the dish. Hopefully the receiver won't get too confused with having more than one sat down from the '4th' lnb selection.
The replies to my thread (_http://www.satellites.co.uk/php-bin/forum/showthread.php?t=30365) were - try it and see what gives - so I'd recommed you do the same, if you get to it before I do, do report back, it might save me trying something silly!
Cheers CTS
