Triax TD 1.1M - Help! Spare Parts!Information exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| Retired Moderator Join Date: 22-12-2003 Location: Brighton
My System: Dreambox 7000, Skystar2 |
LOL, Just put my latest dish together. No instructions included. No instructions on Triax website. Works fine. Looks good. Problem :- I still have these spare parts!!! Anyone with a brain got a clue? Thanks! | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | I thought you were supposed to have bits left over when you do do a building job diy | ||
| | #3 | |||
| Regular Member Join Date: 12-11-2004
| Regular Member Join Date: 16-07-2004 Location: co.down ni
| BIGON i have this dish myself and the piece on the right fits inside the clamp that attaches to the dish (v important) for strength i think piece on left slides inside the dish bracket(the bit the clamp attaches to) hope this helps | ||
| | #5 | |||
Don't suppose you have the instructions still do you? | |||
| | #6 | ||
My System: Dreambox 7000, Skystar2 | Ahhh, no hang on... do you mean that the boxy bit fits inside the large steel clamp that fixes to the pole with the huge 'U' bolts (and seems to stop it compressing too much)? Are the two holes in the boxy bit supposed to bolt through the two small holes on the pole side of the huge clamp? | ||
| | #7 | ||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | Every time the mechanics work on my cars they have bits left over - they throw them away - say they are over engineered. What do you think? | ||
| | #9 | ||
| Super Moderator Join Date: 24-09-2004 Location: Rochdale
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | i know what them bits are for.... they stick them in the box on purpose... knowing you will be really worried when they are left ![]() i have the same dish outside this window.... will take a pick of the back of it when its lighter tomorrow if you like | ||
| "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain." | |||
| | #10 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | This is a 1.2mtr Triax prime focus Antenna http://www.sat-elevation.ch/images/triax7.jpg Want one... | ||
| | #11 | |||
On the curvey part in the photo, there is a bent tag at one end. I could really do with knowing if it goes at the top or the bottom. I'm assuming that it goes INSIDE the main bracket on the dish. The other box-shaped effort seems to sort of fit inside the pole clamp thing, but again, which way up, and does it bolt on? Thanks folks. Better still, a copy of the instructions... I just have to have these things right | |||
| | #12 | |||
| Super Moderator Join Date: 24-08-2003 Location: Dublin....Ireland
My System: Dusty Dreambox 7000s, & Sky HD. |
| Happy Dreaming | ||||
| | #13 | ||
My System: Sky+ Multiroom,Thompson PVR, Dreambox 7000S, 300gig HDD, 1.1m Dish, Moteck SG-2100A DISEQC Motor, Gemini image, 2g USB Stick. ![]() A defender of the Remote Control Brigade, Sir R can flick channels faster than a Robben dive | to be honest mate after looking for them parts on my dish, i aint got a clue what they are?? they must have left them off my dish too lol the picture is probably no help at all, as i took a picture with my phone on zoom, leaning out of the top window ahhaha | ||
| | #14 | ||
| Regular Member Join Date: 04-08-2004
| holy crap, my dish hasnt been able to find the arc properly for months, coukd this be because i have the motor upside down? I have it on the other way than the one in the photo above. With the pole bit facing up, or doesnt it matter? | ||
| | #15 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | LOL, yes, it matters very much, but some motors have the arm above and some below. | ||
| | #17 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Most that look like that will be DiseqC 1.2, a good guide would be the positioning of the cable connectors, if they are on the top, then the motor is probably upside down. Also, if the dish turns upwards when moving away from due Soth, the motor is the wrong way up. | ||
| | #19 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | If you can take a picture of it, we can let you know. The dish doesn't so much tilt down as swivel in its own axis, do you know what make it is? | ||
| | #20 | ||
| i tried taking a pic earlier but it was dark lol, but the dish is brand less, got it from hisat, and i dunno bout motor. But i will take pic later, if i can get flash to work or tomorrow morning | ||
| | #22 | |||
| | #24 | |||
Get the motor elevation set after checking your longitude and latitude. Set it due South - tilt dish get best signal from Thor at 1 deg West and then pan E and W. You probably know all this - for a more detailed run through do a search on setting up a motor. Chances are the pole is not quite vertical - keep trying it's worth it! | |||
| | #25 | ||
@ RedDevil If you could just check this out for me, I'd be very grateful. Did you have to fit something similar to the curvy bit I pictured earlier inside the main bracket on the dish where I've marked no. 1? Also, do you have anything like my box shaped bit inside the clamp, where I've marked no. 2? Finally, do you have a nut and bolt passing through the whole bracket/LNB arm assembly at no. 3? Thanks m8. Also, I found this :- _http://www.satmax.ws/contentproductspecs.htm#Test%20on%20Dishes which might indicate that these two parts are additional strengthening parts for high wind condidtions...??? STICK | ||
| 11m, parts, spare, triax |
Similar Threads | ||||
| Parts from Triax? | bartok | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 23-10-2005 01:33 AM |
| USALS motor sugg'ion please for Triax 1.1M | EDW | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 2 | 12-04-2004 02:28 AM |
| 1.1m Dish ? | Razor | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 8 | 17-12-2003 08:17 PM |
| What are these? (Dirty pictures/naked parts) | T_G | Multi-receiver/TV systems - Domestic only | 2 | 15-12-2003 11:48 AM |
