sirius and position | |
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Try this site howard. http://www.heavens-above.com/countries.asp
__________________ | |||
| "Satellite Expert" Join Date: 01-01-2000 Location: Kernow
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface | You certaily can't do it in West Cornwall; but at the opposite end of the diagonal, even if you can, my guess is that the signal would be weak. wolsty
__________________ wolsty | ||
| Specialist Contributor Join Date: 01-01-2000
| The signals are weak even at north eastern locations, idearly for sustained quality reception you should invest in a 1.5 mtr. There are many reports from individuals that have recieved with a smaller dish but when the rain and poor weather comes then it becomes much more difficult. Some transponders the Europe beam for example can be recieved on a 90 cm However the Nordic beams are around 38-42 db for most parts of North east, and require much larger for good reception. Regards Old Satellite | ||
