Advice on 30E-30W actuator arm | |
| Regular Member Join Date: 01-01-2000 Location: Berkshire
| Hi, all could you please advice on the size of the actuator arm, suitable for moving the dish in the 30e to 30w range? I am also looking for advice on a quality make. Everyone seems to stock and supply Jaeger SuperJacks starting from £25. I had one of these and was not dramatically impressed (noisy both mechanically and electronically - poor reed pulses). Is there a justification to spend more and buy, perhaps, a higher quality product? Who makes a better quality one? Are Echostar actuators any good (sounds attractive, as I have the Echo receiver...) Those start from £50. For reference, I have an 88cm Triax dish with corresponding Triax polar mount. Any advice would be highly appreciated
__________________ Nickolai Echo AD3600, Magic v.1.01, Penta 1.11 Last edited by Nickolai; 23-01-2003 at 05:48 PM | ||
| Hi Nikolai 30 West eh ? Can you providepictures of the dish I can probably advise whats best if I can se it
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| Hi, CH Thanks for your reply. By now I have calculated that I require about 7 inch travel and therefore decided to buy a 10 inch motor. "Echostar" positioner proved to be made by Jaeger. Is there anything else at all? In the US and Australia they have really fancy stuff ("van Weisel", "Meridian"), sounds almost like hi-fi components. But these are very lo-o-ong (start from 18 inch) and expensive: £150+. Anyway, I attach a picture of a setup very similar to mine, borrowed without permission (sorry) from an online SatelliteSuperstore Best wishes
__________________ Nickolai Echo AD3600, Magic v.1.01, Penta 1.11 Last edited by Nickolai; 24-01-2003 at 03:34 PM | ||
| Thats a Triax dish (very good once the reflector is straightened when installing) but a nasty looking polarmount made of soft metal which would need constant attention when moving the dish to the extreme limits. The distance of the actuator from the polar bearings is important, the further away the less force is applied to all moving parts (but the actuator arm has to be longer for the same travel) I doubt there is a 10" actuator made with a 1 inch shaft, as shown in the picture. I would look at getting something slightly more substantial, especially if the dish is on the roof or you live in a windy town
| | #5 | ||
| Specialist Contributor Join Date: 01-01-2000
| I agree with channel hopper the mount may be the reason of some of you problems, The Jaeger super jacks while not be perfect do normally provide a few years of good service. Why not update to a H-H they are if installed correctly they are generally much quietier and more reliable ? SG609 should work well regards Old Satellite | ||
Similar Threads | ||||
| System advice needed | harrisuk | Digital systems | 1 | 22-06-2005 04:30 PM |
| newbie looking for advice on equipment please | vasques101uk | Adult satellite channels | 5 | 19-03-2004 08:12 PM |
| Conax + tita advice, please | stratosg | Conax, Cryptoworks, Nagravision, NDS and Others | 1 | 11-02-2004 10:57 AM |
| advice needed | rob43 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 10 | 30-11-2003 01:40 PM |
| Is there any Porn between 5E and 30W | munkey | Adult satellite channels | 4 | 10-08-2003 11:42 PM |
