Optimum dish size
Thread Tools Display Modes
Old 08-02-2003   #1
"Satellite Expert"
wolsty's Avatar
My System: Humax IRCI5400z, Sony Digibox, Digilogic Freeview box, 1.1m Triax, Manhattan DiSEqC mount, various cards, Season Interface
Optimum dish size
My existing dish is about 90 cms vertical x 80 cms horizontal. On my Hummy, signal strength for the strongest channels shows at about 40% and signal quality at about 30% even on a good day. The signal does vary quite a lot, so the picture is unstable. I'm over 5 degs W and nearly on the 50 deg N latitude, so I'm way off the Thor footprint. I've resigned myself to buying a new dish, but I'd be grateful for views on the optimum size under 1.2 metres (neither my motor nor my pocket will take anything larger)
__________________
wolsty
wolsty is offline   Reply With Quote
Old 09-02-2003   #2
jmc54bc's Avatar
what are you trying to watch/access?
jmc54bc is offline   Reply With Quote
Old 09-02-2003   #3
"Satellite Expert"
wolsty's Avatar
The signal on clear channels, eg Kiosk 1 is fairly stable at about 30%. However, on encrypted channels such as MUTV, Discovery and Kiosk 2 - 22 the signal strength fluctuates visibly and quite rapidly between 20% and 30%. As a result, the picture is unstable when using the Season setup.
__________________
wolsty
Old 09-02-2003   #4
rolfw's Avatar
I would have thought that 1.2 metre would have been close to the minimum for steady reception of those channesl from your location wolsty, I pick them up in anything but bad weather on my 63cm, but am a lot further East and further north than you.
__________________
Rolf
Donate
Old 09-02-2003   #5
"Satellite Expert"
wolsty's Avatar
I had a feeling you were going to say that, Rolf. There are advantages in living out in the Atlantic, so close to the Equator, but easy reception of Thor is not one of them. Still, the primroses in the hedgerows are pretty at this time of year.
__________________
wolsty
Old 09-02-2003   #6
amdaley28's Avatar
Hi there.
There is only two rules regarding dish size.
(1) Get the biggest you can afford.
(2) Make sure that it's properly set up.
Regards.
amdaley28
__________________
Regards.
amdaley.
amdaley28 is offline   Reply With Quote
Old 09-02-2003   #7
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
In a perfect world you would be right amdaley28 but, unfortunately, neighbour relations and planning permission come in to play these days. So, location of dish governs the size allowed I'm afraid.
__________________
Jimbo
jimbo is offline   Reply With Quote
Old 10-02-2003   #8
Pix Meister
pixey's Avatar
@Wolsty, 1.2m CM dish, Lat 51.9 Long 0.09, signal very strong (can't remember exact figure at the moment).
Hope this helps.
pixey
pixey is offline   Reply With Quote
Old 10-02-2003   #9
Old Satellite's Avatar
My recommendation Wolsty would be at your location to go for a 1.8 mtr for reception in less than perfect conditions.
a 1.2 and a 1.5 mtr will provide an improvement but at your location you will most likely loose several transponders at various times.
Regards
Old Satellite
Old Satellite is offline   Reply With Quote
Old 10-02-2003   #10
Mod and septic resident
Channel Hopper's Avatar
Put up a large dish and camouflage it
Before
__________________
Channel Hopper is online now   Reply With Quote
Old 10-02-2003   #11
And after
It doesnt have to be quite so large, but blending in is really helpful
__________________
Old 10-02-2003   #12
rolfw's Avatar
Nice CH, what's the imitation foliage, just standard plastic stuff?
__________________
Rolf
Donate
Old 10-02-2003   #13
A British Army surplus tank/APV cover.
Plastic 'leaves' totally transparent to microwaves and about 20 quid for the larger size that can be tied behind the dish
Stands out a bit in the winter though
__________________
[IMG] code is Off
Forum Jump
Similar Threads
Dish Size For Turksat 1c(42e) And Arabsat3a(28e)? ARIAN_UK_1 DISH SETUP: Single sat, Multi-Sat & Motorised systems 7 04-01-2005 04:14 PM
No idea what size dish do I need for getting Astra 2D in Sicily? ynot62 Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 4 07-12-2004 12:05 PM
Astra 2d..South Sweden, which size dish please! Rabbit Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 89 15-08-2004 11:06 AM
Dish size for Thor 2/3? mrdaveb Digital systems 4 03-03-2004 11:27 AM
Dish Size. RogerP B Sky B Digital and 28.2 East General 1 23-06-2003 08:52 AM
