install thought
Thread Tools Display Modes
Old 30-01-2005   #1
Lightbulb install thought
thought i'd put this in a seperate thread, as this thought has just occured to me.
one of my neighbours (flat roofed terraced house) has a sky minidish installed at near roof level. i knwo it's pointed at 28.2 e, ,so, if i were ot make a large wedge of wood or card, with an angle on it of 29 degrees, and use her dish as a reference, then translate the resulting angle back to my dish, i would be aligned with 1 W, right? (it's late, i'm drunk so this may be totally useless)
i might give that a shot tomorrow if the weather is ok, and i can be bothered cutting a big lump of wood.
georgia_grrl is offline   Reply With Quote
Old 30-01-2005   #2
Nasty Dish Obsession
Lancelot's Avatar
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H
...And thou were the truest friend to thy lover that ever bestrad horse..."
OK as a reference to start.
Are you on T & K Brkts ? if so get another 'U' clamp and put on above the bottom Brckt to take the weight as you move about, then tighten the T & K 'Us' when you are on beam. Takes away all the hard work.
L
Lancelot is offline   Reply With Quote
Old 30-01-2005   #3
good idea lancelot, i'll grab another u bolt before i start its on a kit lashed to a chimneystack, it's not ideal, but its somethign for now, the tree in my road is a bit of a pin, but its apparently diseased anyway, so i might be able to move the dish late rin the year if they cut it down.
[IMG] code is Off
Forum Jump
Similar Threads
First time install success gromit4x4 DISH SETUP: Single sat, Multi-Sat & Motorised systems 7 17-04-2006 11:59 AM
how to install the emu + keys? RomeoX Dreambox General 7 08-09-2005 01:55 PM
Quick install question (not obvious) mikey678 DISH SETUP: Single sat, Multi-Sat & Motorised systems 6 11-08-2005 10:55 PM
How-to Install Newcamd On Original Dmm Images orc Dreambox General 0 29-09-2004 10:27 AM
SKY+ Install Query JohnK Sky+ and PVR Systems 13 08-11-2003 06:46 PM
