Reset a Superjack DG-120 Motor
Old 04-02-2005   #1
Hello,
I´ve got a problem with my Superjack DG120, DiSEqC 1.2 Motor. It stack on one position and manual buttons stoped function also. When I open it and connect to DC current it runs on one side only, continuesly. Manual buttons are dead.
Is it any software problem, is it possible to reset whole thing ?
Is there anyone who had similar problem or just forget it and bay a new one.
Regards,
mkeric
mkeric is offline   Reply With Quote
Old 24-07-2005   #2
My System: IBOOK G4
i have the same problem today
do you have a solution ?
deltacharlie92 is offline   Reply With Quote
Old 24-07-2005   #3
Information Exec
My System: humax 5400z patched to hot 11.1, v box mrk2, 1.1m triax dish, jeager 12" activator .6 lnb, modified pet123 settings
Le grand ordre d'arrangements de Humax
hi,
not to my knowledge, you can not reset in the way you mean, and the very fact that the buttons are not working suggests that there is a fault with the motor, BUT, this verdict is based on the assuption that all the connections are good to the mount, it only needs a fault in the up lead to also give these syptoms.
but as you have said you have supplied voltage directly, arghhhh, thats making my head hurt, so will not comment on that, just check all the connections, the other suggestion would be to make up a short lnb lead, and take the stb to the mount, and try it that way.
when you put the mount back together, make sure the pcb, goes back correctly, mine was not in correctly when i bought it and was shorting out on the case in the back, and giving spurious signals to the motor
hope this helps
phil
phillpayne is offline   Reply With Quote
Old 25-07-2005   #4
gandalfthegrey's Avatar
My System: AZbox HD Gibertini 85cm dish 4 way Diseqc switch........ linksys access point connected to Azbox..
Cool
Hi mkeric...
I had the same problem a while back and brought the motor into work where I have some good electronics guys working for me..they diagnosed the problem to a dead controller card. I e-mailed Jaeger who make the superjack and got in contact with a lady nemed Charlotte who was extremely helpful and mailed a spare card to me within a week. If you feel the motor is dead contact her with your problem and she might be abel to help...
Cheers
Gandalf
Charlotte@jaeger.com.tw
gandalfthegrey is offline   Reply With Quote
dg120, motor, reset, superjack
[IMG] code is Off
Similar Threads
Digital Satellite Receiver Problem (after factory reset) fluppet Receiver software, international Section 2 13-07-2006 02:40 PM
SuperJack DG-120 Sab DISH SETUP: Single sat, Multi-Sat & Motorised systems 5 15-05-2006 08:23 PM
Triax 120 cm? steffan_st DISH SETUP: Single sat, Multi-Sat & Motorised systems 18 14-01-2006 05:17 PM
Reset No Fte 120 educ FTE 2 19-06-2005 02:02 AM
Superjack EZ6000 Positioner Probs iceeman DISH SETUP: Single sat, Multi-Sat & Motorised systems 6 26-06-2003 07:54 AM
