Dish set up
Old 14-03-2005   #1
My System: Triax 1.1m Dish, SG-2100a Motor, Dreambox 7000s, Dreambox 7020s
I live in London, I used to have a motorised system setup but I have now changed to another dish.Unfortunatly I can only get about 50% snr for thor.
I'm starting to feel lost here to.
I beleive I have the correct Lat/long (51.5n/0.07w) According to the motor manufacturer the elevation should be 38.5* and the declination (30-dec) = 22.6*.
My setup is a Triax Dish, SG-2100a motor and a Dreambox.
I've got a digisat pro meter to help,but no luck..
Any suggestions?
samedin is offline   Reply With Quote
Old 14-03-2005   #2
rolfw's Avatar
Real name: Rolf
Are you setting 1W as your 0 degree point? You don't say what size your dish is, but Thor is reasonable for reception in your location and you should be able to bring the quality up a bit more.
Rolf
Old 14-03-2005   #3
Hi Rolf, Sorry my dish is 1.1m and I used to get Thor with no problems at all (around 86*).
Yes I use 1w as my zero, or I acctually pointed the motor to 1w and then tried to find Thor.
Old 14-03-2005   #4
rolfw's Avatar
Real name: Rolf
Crumbs, Thor should be storming in with a good signal and very high quality with that dish. I presume that you have zero skew on your LNB, so it should just be a case of tweaking with the meter.
Rolf
Old 14-03-2005   #5
Thanks again for your response. I'll have to get up on the roof again then!
Cheers!
Old 14-03-2005   #6
Argghhh...
I cant get a better signal than 47->56 (SNR).
Is there anyone in the London area who would like to lend a hand (wishful thinking).
I'm quite sure I pointing in the right direction (the compas is more or less dead on 0*).
If I move the dish left/right I loose signal, same for updown.
The triax dish is diffrent from the @Sat dish I used to have (motor now mounted at the bottom of dish) if that makes a change.
The digisat pro meter shows about 61 SNR...still no lock on the dreambox however
Old 14-03-2005   #7
rolfw's Avatar
Real name: Rolf
Sounds like you may not be on 1W, try moving the whole assembly 5 degrees in either direction.
PS Sorry for asking about your dish size, didn't look at your profile system information and it's there. DOH.
Rolf
Old 14-03-2005   #8
Smile
Hi, will try that tomorrow, getting a bit dark now
Also trying to install a diffrent image as I had some problems with the hydra one I had...
Wasnt you mate, I just added the dish size
Old 14-03-2005   #9
Ok, this is getting really wierd now.
I reflashed the Dreambox and the motor went all the way to the east, even though I tell it to move to another satellite it just stands there...
Any ideas???
dish, set
[IMG] code is Off
Similar Threads
Will this cabling set up work?? cslogg Terrestrial Television, Digital and Analogue 8 11-02-2004 09:39 PM
Dave the pub landlords set up digimac_uk DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 11-02-2004 11:18 AM
Disney set launch "Daytime" on Freeview net1 Terrestrial Television, Digital and Analogue 0 03-12-2003 08:47 PM
BBC set to lose cup TV rights net1 Daily Satellite and Broadcast industry News 0 15-07-2003 08:38 PM
BBC channels set at default. net1 Sky Digital (BSkyB) and Astra 28.2 East General 4 04-07-2003 02:24 AM
