how to use sun or compass for true south | |
| Specialist Contributor Join Date: 21-08-2004 Location: Wales
My System: Technomate 1500CI+, Comag SL55 and Skystar2 on a 104 cm motorized dish and Humax HDCI200 on 90 cm motorized dish. |
How is it possable to find true south useing the sun postion is it at 12 o'clock British summer time or 1 o'clock ? Also can someone explain how to use a magnetic compass to find true south takeing into account magnetic devation from a given loaction in the UK. Last edited by remlap; 24-04-2005 at 12:10 AM Reason: title used before | ||
| Specialist Contributor Join Date: 01-01-2000
| A compass is accurate to about 3° at the moment for most of the UK. Unless you have a very expensive compass that's within the accuracy of the compass and the ability to line up your dish with the compass. | ||
| | #3 | |||
| Dumb Satellite Babe Join Date: 05-11-2004 Location: Ibiza, Spain
My System: Technomate 5500CIP Force 1145S Pace 2600 SS2 pci & USB Channel master 1.8m 1.2m & HH motor AMD 64 bit, Linux & Windows XP2 |
all will be revealed | |||
| Guest
Posts: n/a
| Magnetic north is somewhere in canada at the present time. Hence the three british ladies racing to be the first female team to reach it. The sun is due south, in the UK at 12 noon GMT (1pm BST) if you are on the zero meridian. For each degree off of that the sun appears to have moved 4 minutes in time. ie, I'm at 1*east so my due south is 11.56GMT or 12.56BST. For some one in Poole, 2*west, the sun would be due south at 12.08GMT (13.08BST). For someone in Fishguard, 6*west, the sun would be due south at 12.24GMT (13.24BST) etc etc. The above applies to the UK, where we have one time zone. H-B | ||
| | #5 | ||
| Member Join Date: 13-04-2005 Location: Sweden
My System: Dreambox 7020S with rotor and official Canal Digital Family package, Asustek DVB-T for FTA terrestrial channels | You also have to correct for the Equation of Time which can differ more than 15 minutes. http://www.sundials.co.uk/equation.htm | ||
| | #6 | ||
| Regular Member Join Date: 08-02-2005 Location: Lot, Dordogne, Correze border.
My System: Dbox + Skystar2, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky. | Point the hour hand at the sun (use a vertical stick or object to cast a shadow if you have difficulty), split the angle between the hour hand and the 12 oclock position to give a north / south line. I've used this method to help in setting up satellite dishes all over Europe - from Norway to Portugal without a compass. | ||
| | #7 | ||
| Guest
Posts: n/a
| Useing the sun at noon (GMT) is a close enough approximation and starting point. Agreed that "the equation of time" will make a difference, at a minimum on 16th April and maximum on 5th May (at this time of the year) but as stated above "it's a starting point and we all have had to tweak our dishes for maximum signal strength. H-B | ||
Similar Threads | ||||
| Using a compass find magnetic south | dinojoice | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 9 | 13-10-2007 05:08 PM |
| Astra 2d..South Sweden, which size dish please! | Rabbit | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 89 | 15-08-2004 11:06 AM |
| No vertical 2d in south east Sweden | steffan_st | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 19-02-2004 06:51 PM |
| South African TV to launch on Sky | net1 | B Sky B Digital and 28.2 East General | 0 | 21-08-2003 04:06 PM |
| Compass bearing corrections. | clarke belt | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 2 | 14-03-2001 01:14 PM |
