120cm Gregorian
Old 11-06-2005   #26
My System: Fibo 90cm-Maybe the only one in Japan!!!
Coming from you Likvid thats means alot, 300 for just the az/el?!?
If it would last you 10+ years it may be worth it...
Have you seen one of these perform?
lloyd21 is offline   Reply With Quote
Old 11-06-2005   #27
WOW, that thing is outrageous....the arms on it look robotic!!! Not only that he has two cas120 AND cas90!!!, Cannot tell by the pictures does it come with a polariser(seavey quality)??? Also do you know what LNB it is running.
Old 11-06-2005   #28
No i haven't, i think they are too expensive for people to buy, i mean you can get the Gibertini 125cm for about 130 euro today including AZ/EL mount.
Likvid is offline   Reply With Quote
Old 11-06-2005   #29
The feed is matched to the reflector, the LNB i don't know about, it's Kathrein specific.
If i bought the antenna i would have stripped the feed from the LNB and put a SMW or Invacom there instead.
The feed is everything, i think the performance would degrade if you put something like a Invacom with integrated feed on that reflector, they are usually made only for 0.6 f/d reflectors.
Just look at the Gibertini, it got 0.66 f/d, a budget Invacom LNB with feed would not perform as good as a optimized feed for it.
You can buy a optimized feed from Seavey but it will cost you around $300 or something last time i checked.
WOW, that thing is outrageous....the arms on it look robotic!!! Not only that he has two, Cannot tell by the pictures does it come with a polariser(seavey quality)??? Also do you know what LNB it is running.
Old 11-06-2005   #30
Yes i know, it's German quality, you get what you pay for like i said.
Old 11-06-2005   #31
Would it be worth it then??? Even as high as quality as it is there are still the physical limitations of a 120 no??? over say a 125 of decent build quality???
The Fibo gregorian "theory" corrects this with a dual reflector.
Old 11-06-2005   #32
I think you said it before, the market is so flooded with cheap stuff it's crazy, When I do buy...pretty much anything, I always get the best I can afford, or will just save up then buy it. I have acutally *SAVED* money using this method.
When I buy it or something similar, it would be outfitted with equal quality LNB/Polariser/Feed.
Old 11-06-2005   #33
The only REAL advantage of a gregorian dish is that it got much better cross-polarization than a normal dish.
The subreflector phase out the opposite polarization and is mostly used for uplinks.
There are tests done that shows this remarkable improvement on phasing out the opposite polarization due to the subreflector.
Tests also shows that a gregorian dish performs about 10% better than a normal offset dish at the same size.
If i had the space and couldn't get larger dish than 120cm and didn't mind spending what the Kathrein cost, i would buy it.
The Fibo 120cm is so hard to get so you can look forever.
If you appreciate quality you should buy the Kathrein.
Old 11-06-2005   #34
Yeah that's what i think also, i always buy the most expensive stuff i can afford, i hate cheap quality, people like buying CHEAP these days, it's the fashion word of modern times, the cheaper the better people thinks.
Quality costs, and will always do.
Mostly to blame for this are all Korean satellite manufacturers flooding the market with cheap stuff.
You want a good retailer for the Kathrein in Germany?
Try this!
https://shop.mascom.de/index.php?sid...e3a20b91398e0b
Old 11-06-2005   #35
I do appreciate quality like most people on this board...but not at any cost.
The Andrew Type 120 cost 1/4 and is marginally *worse*
Thanks for the information about the gregorian. thats pretty interesting.
Old 11-06-2005   #36
Read this technical document about gregorian reflectors.
http://www.andrew.com/search/docviewer.aspx?docid=6829
Old 11-06-2005   #37
Red face
A Cas90 = 200Euro
A Cas120 = ~400Euro
Lets just say hypothetically you mulled it over and decided to buy one.
How would two coupled Cas90's perform over a single 120
I agree with the whole Korean Cheap summery...too bad the Mrs. is all about quantity over quality. Im the exact opposite.
Here is a conversation we had just recently about some knives
Mrs lloyd21...Look that a good price on a 30pc knive set
me...no its not its garbage
Mrs. lloyd21....but you get 30pc's
me....their garbage....let just spend the money and get the Wustof
Mrs. lloyd21....the price is like X10 *Yada* (Japanese girls word for No Way)
me....you'll be buying new ones next year
I think you get the picture
Old 11-06-2005   #38
So Andrews makes gregorian....im really interested
Old 11-06-2005   #39
Hehehe.....
What country are you from? Japan?
I can't comment about coupling two CAS90s together as it is nearly impossible and if it worked it would be like 1.8 meter, more like 1,20 meter or something.
Old 11-06-2005   #40
Andrew bought Channel Master in 2003, Channel Master couldn't face their financial problems so Andrew took over all production, it's really a Channel Master design from the beginning.
The dual-optics or gregorian dishes they offer today are only available in sizes of 1.8m and 2.4m in their VSAT range that was branded Channel Master before.
Why don't you install the dish as this guy have done, then you can have a 2.4 meter dish outside your balcony.
120cm Gregorian-08050050-jpg
Old 11-06-2005   #41
Yes Im in Japan
Only 1.8m and above...Likvid your like my pastor the bearer of good and bad news
Not that I would know how or even do a good job.....how would one Make a gregorian
Here is one of you old posts
rolfw commented it was homemade
http://www.sat4all.com/upload//72536...anzijkant1.JPG
Old 11-06-2005   #42
Yes it's homemade.
Old 11-06-2005   #43
My wife would really say YADA
Old 11-06-2005   #44
How would one pull that off???
Even better question is it even effective?
Old 11-06-2005   #45
Here you can see the mount of my dish with the Jaeger SMR-99G.
The back view picture is when the dish is pointed to Hispasat.
120cm Gregorian-backview-jpg   120cm Gregorian-sideview-jpg
Old 11-06-2005   #46
Nice....is you dish fully exposed, it looks like its behind the balcony wall a tad no?
Old 11-06-2005   #47
Yes it's inside the balcony on a floorstand.
The balcony wall is no problem as the dish angle pass the wall.
I have not installed the polarizer yet as i am waiting for delivery from Germany.
Here you can see two more pictures, the first the dish is pointed at 53 degrees East and the second picture shows the ground mount on the balcony.
The 36v motor cable clamped between the door and floor is only temporary, i will install next week when the new polarizer arrives a full shielded 7-core cable nicely.
120cm Gregorian-53east-jpg   120cm Gregorian-mount-jpg
Old 11-06-2005   #48
Very nice equipment...well done. I was under the impression you were running a seavey polariser with that SMW.
A question about your SMW lnb....how do these compare to the likes of a Norsat Pll's, I have searched far and wide for Lab test but cannot find them. I have always heard that SMW and Norsat were the among the best, is this actually true?
Also are pll's really necessary or is just smoke and mirrors, I read conflicting information on these forums and other....Old Satellite says they are great, Others say unnecessary.
Old 11-06-2005   #49
Seavey was too much losses in the waveguide, i am changing that for a Chaparral that i know works good.
Next week i have the SMW + Chaparral, will post picture then.
I have no experience with Norsat, but they don't handle the whole frequency range of 10.7-12.75GHz.
My SMW is not PLL, it's DRO.
PLL LNBs are really only usefull for data broadcasts where you need pin-point accuracy of the signal.
PLL LNBs are hyped for satellite-TV, not for DATA!
SMW are the best, they are handmade to custom order.
My SMW LNB is custom ordered with LO +-1MHz which is really great for a DRO LNB, PLL LNBs can go down to +-250kHz i beleive.....
Old 11-06-2005   #50
Here is my play room with all stuff.
You can see my server there and the 50" plasma and all.....
120cm Gregorian-room-jpg
120cm, gregorian
[IMG] code is Off
Similar Threads
antena de 100cm ou de 120cm? crispim23 Questões Frequentes. FAQs 1 22-06-2006 04:25 PM
My System Ahvenisto Picture of Members' Setups and general satellite installations 1 25-06-2005 09:29 PM
Pace MSS508-IP + Philips Gregorian dish. petew Analogue systems 8 16-03-2005 04:49 PM
Fibo Gregorian and Diseqc motor Likvid Fibo Owners Club 2 22-10-2004 08:32 PM
Gregorian dishes Likvid DISH SETUP: Single sat, Multi-Sat & Motorised systems 6 28-07-2004 01:16 PM
