120cm Gregorian
Old 11-06-2005   #51
My System: Fibo 90cm-Maybe the only one in Japan!!!
Did you order your LNB from SMW's website?
I see you your getting birds clearly out of footprint in Sweden. with the Fibo, according to my understanding is you would need 150~180cm for some of those satellites.
Does anybody you happen to have Agila2 KU enhanced footprint handy from the Tele-Sat CD I want to see if there is anyway possible to pick this bird.
My problem remains the same, to get this satellite. Agila2 is one of my Sourthern most satellites @ 146E, Yokohama is @ Lat 139E, but Its drown out by Superbird C @ 144E.
If the SMW would work I would be more than happy to buy it.
I
lloyd21 is offline   Reply With Quote
Old 11-06-2005   #52
Nice Plasma, are you in the IT field as well?
Old 11-06-2005   #53
Yes, unemployed IT-Security Consultant.
Getting new job soon i hope.
You write good english for being Japanese mate....
Likvid is offline   Reply With Quote
Old 11-06-2005   #54
I used to work as a broadcast engineer at Teleports travelling around the world, mainly the U.S and Latin America with my own company 15 years ago so i was dealing pretty much with SMW and other professional equipment.
I
Old 11-06-2005   #55
Are you comfortable where your at? FYI:Ex-Pats out here in the IT field are making good money, IA's and Financial guys right now are shoveling it in...just an idea.
I found somewhat of a Print for agila2
http://www.tracksat.com/My%20Webs/Fo...-E-KU-band.gif
Im between the "T" and "R" straight accross Yokohama Japan, Can I pull this down with a 120cm, Any ideas anybody?
FWIW: Agila2 C is obtainable with a 150cm
http://translate.google.com/translat...26lr%3Dlang_ja
Old 11-06-2005   #56
Satcodx says you need a 2 meter dish.
Old 11-06-2005   #57
Smile Fibo gregorian
I have a 90cm fibo gregorian complete but with a burnt out optical sensor, recent cogs, good motor etc,includes lnb, best of all it is free to a good home providing you collect it. It is near Hastings in East Sussex. Please note that you can`t use it with a v-box as it needs a 5v supply for the sensor unless you can figure out a way of using a relay so that a seperate 5v supply is used only when the dish is turning, { that is how I managed to blow the sensor]. I`m sure that with a little inginuity that the sensor can be repaired, So if it is of any use, First come first served as they say. Regards Saabtech.
saabtech is offline   Reply With Quote
Old 11-06-2005   #58
Thanks Likvid for the info.
Have you ever heard of or used JRC LNB's I have been offered a few at a good price, Also a Comstream.
What feed and LNB are you using for C-Band?
Old 11-06-2005   #59
Saabtech, What would it cost to fix? Will you ship?
Old 11-06-2005   #60
Fibo
I do not know what it would cost to fix, but it is a small circuit board with some resistors,so I assume that it could be fixed but i am not up on electronics so asking me is a bit like asking a pig for the time! I simply do not have the time to get involved with shipping and I do not have any suitable packing so it does need to be collected, So, sorry, Saabtech.
Old 11-06-2005   #61
Never heard of them, i never tried C-band on this dish, it would be tough to install C-band onto this dish as it's made for Ku-band.
Old 11-06-2005   #62
My mistake I thought you were picking up C-band with this dish...
FWIW: Ebay.de has some VERY good deals on those Kathrein dishes mentioned earlier in this thread....dont seem to see any 120's however.
Old 11-06-2005   #63
There was a CAS120 recently for 250 euro.
Old 11-06-2005   #64
I would pick that up for 250....Here is a good question for you since they are in the same price range..
What would be your choice between a Cas90 or a Fibo Master Focus 90 They both run for roughly 200Euro Currently?
Old 11-06-2005   #65
Fibo 90cm without question...
By the way, i have a brand new Fibo H-H mount for sale with motor for 100 euro.
This is something for you
Ebay.de/ws/EbayISAPI.dll?ViewItem&category=77762&item=5780738477&rd=1&ssPageName=WDVW" target="_blank">http://cgi.Ebay.de/ws/EbayISAPI.dll?...sPageName=WDVW
Old 11-06-2005   #66
I would get arrested trying to put that on my balcony
Interesting you say the Fibostop
The craftmanship on these Kathrein's are obscene
Ebay.de/ws/EbayISAPI.dll?ViewItem&category=77762&item=5780278979&rd=1&ssPageName=WDVW" target="_blank">http://cgi.Ebay.de/ws/EbayISAPI.dll?...sPageName=WDVW
I think he says it a 120 also, Wonder what shipping to Japan would be???/
Old 11-06-2005   #67
Here is some German antenna porn for anybody into that sort of thing, and hasent seen it before
http://www.keding.de/produkte/sat_antennen.html
Old 11-06-2005   #68
You want to know who makes the old Kathrein prime-focus dishes?
It's Precision Antennas in the U.K and they are still available but you have to buy it from Precision.
Old 11-06-2005   #69
Really, You just put a wrench in my brain....im going to have to look into Precision. That is outstanding work. Looks like it would last 20+ years
Here is a Dopplefocus Kreiselmeyer going for cheap if anybody is interested and live in Germay
Ebay.de/ws/EbayISAPI.dll?ViewItem&category=77759&item=5781204614&rd=1" target="_blank">http://cgi.Ebay.de/ws/EbayISAPI.dll?...781204614&rd=1
Look at these Kathrein Feeds sheets
http://www.kathrein.de/en/sat/produc...ad/uas_022.pdf
http://www.kathrein.de/en/sat/produc...ad/uas_023.pdf
Opinions on these?
Old 12-06-2005   #70
Kathrein dishes are good because they follow the best design concept on the old prime-focus antennas, the have no bolts thru the reflector, the steel ring is welded to the back of the reflector which makes the parabolic shape perfect.
There is a manufacturer in Finland who follows the same concept, they fast the mount to the edge of the reflector which have no impact on the reflector, that is two of the best designs i know about.
Usually they put bolts right thru the reflector, one classic and very bad example are the Triax dishes, they have made a big hole for the feedarm, how stupid isn't that?
You should never touch the reflector as it can warp and other things over time.
Old 12-06-2005   #71
Do you happen to know the name of the manufacturer?
I just contacted a seller in Germany reguarding the Kathrein Cas 120, Im very seriously considering to picking one of these up. You just added gas to the flame.
Old 12-06-2005   #72
http://www.aerial.fi/Satellite%20TV%20antennas.pdf
Old 12-06-2005   #73
Would you only get them directly from the manufacturer?
Do you know any cost associated?
Old 12-06-2005   #74
Don't know anything about prices.
You have to contact them directly for importing to Japan.
They are shipped in a wooden crate for protection.
Old 12-06-2005   #75
I e-mailed them and will post result, I asked prices for the as12/18 and 24
120cm, gregorian
[IMG] code is Off
Similar Threads
antena de 100cm ou de 120cm? crispim23 Questões Frequentes. FAQs 1 22-06-2006 04:25 PM
My System Ahvenisto Picture of Members' Setups and general satellite installations 1 25-06-2005 09:29 PM
Pace MSS508-IP + Philips Gregorian dish. petew Analogue systems 8 16-03-2005 04:49 PM
Fibo Gregorian and Diseqc motor Likvid Fibo Owners Club 2 22-10-2004 08:32 PM
Gregorian dishes Likvid DISH SETUP: Single sat, Multi-Sat & Motorised systems 6 28-07-2004 01:16 PM
