120cm Gregorian
Old 10-06-2005   #1
My System: Fibo 90cm-Maybe the only one in Japan!!!
Question 120cm Gregorian
Hello,
Does anybody know where I can find a 120cm gregorian dish, I found a 90cm Master Focus (FIBO) but I think im going to need a touch more gain.
lloyd21 is offline   Reply With Quote
Old 10-06-2005   #2
Mod and septic resident
Channel Hopper's Avatar
Why a Gregorian?
The cost over a standard dish is unlikely to be worth the improvement
I dont know of any decent ones out there , stay clear of Spanish ones
Old 10-06-2005   #3
A U.K dealer recently sold his 120cm Fibo dish last week for £350, it was used.
They aren't made anymore since 8 years back or so....
Likvid is offline   Reply With Quote
Old 10-06-2005   #4
Thanks CH,
My understading is that a 90cm equates to a ~110 (Likvid mentioned it I think), So a 120cm would equate to roughly a ~140/145??, reasoning being is I live in a apartment and the Biggest I could get away with would be a 120 MAX.
Old 10-06-2005   #5
Thanks Likvid,
I got a quote for 350E from satmuller for a 90cm with motor, I really want a 120, Do you happen to know any Backyard specials?
How would I find out cost freight from Germany to Japan?... DHL?
Old 10-06-2005   #6
I bought my Fibo 90cm from Satmueller a year ago or something for that price.
Forget the Fibo H-H mount, it's useless, i hate it.
Buy it with the AZ/EL mount instead and then buy a Moteck 2100 motor or even a Jaeger 36Volt motor if you want that instead.
I don't know anyone selling their 120cm, they are very sought after in the market and Fibo never produced many.
Reason i bought the Fibo was because i couldn't have anything bigger on my balcony, otherwise i would have bought a Channel Master 1.2m dish for over half the price and get better performance.
Read my thread about the Jaeger SMR-99G mount i bought to the Fibo, it works perfect.
Originally Posted by lloyd21
I got a quote for 350E from satmuller for a 90cm plus motor, I really want a 120, Do you happen to know any Backyard specials?
Old 10-06-2005   #7
Thanks Likvid
He quoted my 195E for the 90cm Az/El fixed, Right now I have a Pansat PM900 for my rubbish fortecstar, Here is a quick question I live in Yokohama, Japan I am looking to get Agila2 out of the Phillippines, what would a 90 get me, I not really good judgeing these types of things
139E 38N
I can afford to get a similar set-up as yours Likvid, How far could I see do you think?
Old 10-06-2005   #8
You should receive these channels at your location and the Fibo 90cm dish.
http://pal.pp.se/~kalle/satcodx.html
Agila 2 says a 2 meter dish is required at your location.
Here is a picture of the 120cm also....
http://home.xi.no/henriksen/bilder/5east.jpg
Old 10-06-2005   #9
http://209.4.91.164/images/FS/funny/homer-drool.jpg
homer<> 120 Georgian <>drool<>
Yes thats the one
Thanks for the list Likvid,
I pull all that down with my fortecstar...so not much of a difference with a 90, how is the FIBO for dxing?
FYI: Here is a Japanese DX'er Spectrum Analizer screen shots for Ku
http://translate.google.com/translat...26lr%3Dlang_ja
He is also gettin as far as Intelsat 902 and NSS 703!!! on a 1.8 for C-Band
Old 10-06-2005   #10
Fibo is great, high quality.
I can't get a better dish right now in my situation, i can get from NSS7 at 57 East to Intelsat 801 at 31.5W.
I receive even weak analogue signals from Arabsat 2B at 30.5 East with my low threshold extension set to max, comes in at 1-1.5dB C/N approx.
Old 10-06-2005   #11
Thats incredible!!! In your current situation, how would a 120 prodelin or the like compair?
I can go as high as a 120 in my apartment, What would you recommend for me, my guess is I could get the most gain out of a FIBO or cassegrain, money is not necessarly an object currently, unless it just outrageous
Old 10-06-2005   #12
Andrew Type 120 is the dish of your choice if i was in your position and couldn't get a Gregorian Fibo 120cm.
My dish is comparable to a Triax 110.
Old 10-06-2005   #13
http://www.sepatriot.com/pop_up/10_12_dual-.jpgIs this a georgian from patriot?
Old 10-06-2005   #14
Yeah it's Patriot, don't know how it performs, doesn't seem like the high build quality of Fibo.
Old 10-06-2005   #15
Reason I asked is Patriot has various sizes for these dishes, under there tx/rx antennas...I searched the forums and patriot really have a bad rep. on her...or any forum for that matter...unlike Jonsa for Fortecstar.
They have these in 1m and 1.2 georgian "style" not sure if its a true or not. It may be an alternative for somebody that would need one.
Likvid Do you know if they make a cassegrain at 120?
Old 10-06-2005   #16
Yes they have a 1.2m Gregorian dish also.
Here you have the manual
http://www.sepatriot.com/manuals/1.2m%20Dual%20Optic.pdf
Old 10-06-2005   #17
Goosh....it's performing worse than the Andrew Type120 or Prodelin 1130 dish.
Old 11-06-2005   #18
Interesting
Here is a spec sheet comparison- For those that care
Patriot1.2 Andrew T-120 Prodelin-1130
Gain Mid-Band\ 42 42 42
3db beamwidth 1.4 1.6 1.4
Side lobes\ -23
Cross Pol >35 >30 >30
Off Set Angle 22deg
F/D .635
Noise @ Elevation 24-Deg K @30 43-Deg K @30
46-Deg K @20
Old 11-06-2005   #19
Looks like andrew wins hands down.....Anybody have a spec sheet for a Fibo?
Old 11-06-2005   #20
According to this guy, Fibo's are being sold as Master Focus
www.satellite-calculations.com/Fibo/fibo.htm
Fibo 90 Spec sheeet
Gain @ Mid 40.9
Efficiency 82%
Cross Pol <-30db
Beamwidth 1.57
Likvid are these accurate?
Old 11-06-2005   #21
The Andrew is a Channel Master item
Old 11-06-2005   #22
No.
40.9dBi is a bit optimistic, i would say about 40.3dBi or something.
Fibo 90 Spec sheeet
Gain @ Mid 40.9
Efficiency 82%
Cross Pol <-30db
Beamwidth 1.57
Old 11-06-2005   #23
Also would like to throw Katherin into the mix, Does anybody have any experience???
http://www.kathrein.de/en/sat/produc...ad/cas_018.pdf
Decent Specs also:
Gain
10.70~11.70 = 41.5
11.70~12.50 = 42.15
12.50~12.75 = 42.5
The Fibo 120 gets
Gain @ 11.7 = 42.4Dbi
Looks like the fibo is a touch better, but unavaliable.
Old 11-06-2005   #24
That's the CAS120 Offset dish, very good dish, probably the best 120cm on the market but it will cost you a arm and a leg.
The dish goes for around 400 euro and the AZ/EL mount for around 300 euro.
Just look at the build quality, it's amazing, it's commercial quality and you get what you pay for.
Old 11-06-2005   #25
Look at Stefan DX site, click on the images and you will see his CAS120 setup.
Nice eh?
http://ww.dxstefan.de/images/anlage/new_images/
120cm, gregorian
[IMG] code is Off
Similar Threads
antena de 100cm ou de 120cm? crispim23 Questġes Frequentes. FAQs 1 22-06-2006 04:25 PM
My System Ahvenisto Picture of Members' Setups and general satellite installations 1 25-06-2005 09:29 PM
Pace MSS508-IP + Philips Gregorian dish. petew Analogue systems 8 16-03-2005 04:49 PM
Fibo Gregorian and Diseqc motor Likvid Fibo Owners Club 2 22-10-2004 08:32 PM
Gregorian dishes Likvid DISH SETUP: Single sat, Multi-Sat & Motorised systems 6 28-07-2004 01:16 PM
