Dish Elevation
Thread Tools Display Modes
Old 13-07-2005   #1
My System: -
Dish Elevation
Hello, I am sitting up a satellite dish tomorrow for the first time, using the SMWLink program I have calculated using my lat. and long. what the elevation of my dish should be, it has said the dish should be tilted at 28degrees, I have looked at the markings on the bracket on my dish and that is alot more slanted than my existing dish and other dishes in my area (by the way I am setting up the dish to receive hotbird 13degress and astra 19 degrees) is this correct or should I just position the dish like all the other dishes in the area (more or less flat vertically off the wall). I would appreciate some help.
josephgall is offline   Reply With Quote
Old 13-07-2005   #2
rolfw's Avatar
You may find that the other dishes are pointing at Astra 28.2 E, this is lower in the Sky than 13E say.
__________________
Rolf
Donate
Old 14-07-2005   #3
Now leaving, thanks all.
My System: LNB, Dish, Motor, Cable, Receivers all taken down and donated to a newbie.
You might find that the SMW link indicates the elevation of a centre fed dish. If you have an offset dish you have to take this into account. For the UK, offset dishes are not far off of vertical .
regards Redmund
RedAltoGL is offline   Reply With Quote
Old 14-07-2005   #4
My System: -
regards Redmund
Yes my dish is an offset dish, thanks
Old 14-07-2005   #5
rolfw's Avatar
SMW Link gives the Elevation of the satellite, it is the same for both prime focus and offset dishes..
__________________
Rolf
Donate
Old 14-07-2005   #6
spiney's Avatar
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
the marked scale is very "rough and ready", to actually find the satellite you have to very slowly and carefully move the dish (a meter with audio output is helpful) until receiver locks onto a signal.
If in UK, then all offset dishes "seem to" be pointing straight at the horizon, for a reasonable distance east and west of direct south.
spiney is offline   Reply With Quote
Old 14-07-2005   #7
@rolfw
"SMW Link gives the Elevation of the satellite, it is the same for both prime focus and offset dishes.."
Agreed, but the little piccy shows a centre fed dish and I think that was where the original poster was having problems.
regards Redmund
Old 14-07-2005   #8
rolfw's Avatar
May well be, but I got the impression that the thread starter was comparing his new dish setting (a la SMW) to the other dishes in the area, not the illustration on the calculator itself.
__________________
Rolf
Donate
[IMG] code is Off
Forum Jump
Similar Threads
Setup the Dish T24 DISH SETUP: Single sat, Multi-Sat & Motorised systems 23 11-05-2008 11:01 PM
Motorised dish elevation Settings hellohellopal DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 19-02-2006 09:33 PM
Want to set elevation, no horizon Artist 2004 DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 17-10-2005 10:26 AM
Elevation andy653cc DISH SETUP: Single sat, Multi-Sat & Motorised systems 7 05-01-2005 06:28 PM
Elevation question kb91058 DISH SETUP: Single sat, Multi-Sat & Motorised systems 24 05-06-2004 07:20 PM
