Hotbird Problems | |
| Regular Member Join Date: 18-11-2003
I have a problem with some transponders on Hotbird which I wondered if anyone could give me some tips on. I posted this on another forum and was told my dish might be a bit off, but I’ve checked it and re-checked it and can’t seem to get it any better. There’s nothing obvious barring the line of sight either. I have a Technomate TM5000 DAPCI. I'm in the SE and have an 80cm dish. Signal strength across the board for Hotbird is roughly 70-75%, however Pic Quality varies. Once it gets down to 20% or below I either get massive pixilation or no picture at all. There are also a number of frequencies which don’t even register, although the signal strength is there. Below is a list of frequencies which I simply can’t receive. I have tried this on a different receiver, also with no luck. 10949v – HB4 – Wide 10992v – HB6 – Europe 11054h – HB6 – Europe 11137h – HB6 – Europe 11200v – HB6 – Europe 11221h – HB1 – Superwide 11283v – HB1 – Superwide 11304h – HB1 – Superwide 11345h – HB1 – Superwide 11387h – HB1 – Superwide 11513h – HB1 – Superwide 11604h – HB6 – Europe 11623v – HB6 – Europe 11642h – HB6 – Europe 11681h – HB6 – Europe 11766v – HB2 – Wide 11804v – HB2 – Wide 11919v – HB2 – Wide 12476h – HB3 – Wide 12564h – HB4 – Wide 12692h – HB4 – Wide 12713v – HB4 – Super 12731h – HB4 – Super What confuses me is that the beams all vary, the actual satellite varies so I can’t find a pattern to go after as such. One thing to note, on some channels, for example Tele Melody on 11034v (Hotbird 6) the pic quality can vary over the course of a day from 20% up to about 40%. Can’t think of any reason for that either, although I’m no expert. Has anyone got any tips that I could try out? It’s immensely frustrating!!! Any pointers would be greatly appreciated. | ||
| | #3 | |||
Haven't changed the skew...just put it in as it were. Could you explain in more detail (and how/why it works) and how much I need to skew it? By that I presume you mean twist it round a bit? | |||
| | #4 | |||
| Regular Member Join Date: 08-03-2005
My System: Opentel 3500 FL, LNB 0.6 dB, 60 cm Fe |
| | #6 | ||
| Now leaving, thanks all. Join Date: 20-06-2005 Location: London
My System: LNB, Dish, Motor, Cable, Receivers all taken down and donated to a newbie. | Hi moordown66 You do not just give the lnb "a twist", everything in digital satellite setting up is "just a small movement, allow to settle, then check levels" then continue until you get the best results. You mention that you are in the SE, assuming that you are somewhere near 51 north and 1 east, the skew angle (according to the SMW Link) is approx 9.6 degrees clockwise from the vertical looking into the dish from the front. I will go and have a look at the channels that you are having trouble with. regards Redmund Last edited by RedAltoGL; 20-07-2005 at 12:26 AM | ||
| | #7 | ||
My System: LNB, Dish, Motor, Cable, Receivers all taken down and donated to a newbie. | @ moordown66 Running an old Tech 5000DA, 0.6 lnb, 25m (approx) RG6 cable, 85 X 90cm dish, NW London Receive levels ie Strength/Quality on the transponders you mentioned as follows 10949v – HB4 – Wide 80strength/37quality 10992v – HB6 – Europe 11054h – HB6 – Europe 11137h – HB6 – Europe 82s/96q 11200v – HB6 – Europe 11221h – HB1 – Superwide 11283v – HB1 – Superwide 80s/70q 11304h – HB1 – Superwide 11345h – HB1 – Superwide 11387h – HB1 – Superwide 81s/88q 11513h – HB1 – Superwide 81s/88q 11604h – HB6 – Europe 80s/98q 11623v – HB6 – Europe 81s/98q 11642h – HB6 – Europe 80s/99q 11681h – HB6 – Europe 81s/99q 11766v – HB2 – Wide 80s/81q 11804v – HB2 – Wide 80s/40q 11919v – HB2 – Wide 80s/69q 12476h – HB3 – Wide 80s/61q 12564h – HB4 – Wide 12692h – HB4 – Wide 81s/60q 12713v – HB4 – Super 80s/98q 12731h – HB4 – Super 79s/98q I did not look at all of the transponders on your list as the list in my receiver is way out of date, I have not done a re-scan of 13 east for ages. Different sats in the cluster, different o/p powers, different ages of sats, different beams, hence different quality readings obtained. Suggest a slight tweak in azimuth and/or elevation, different lnb, larger dish. Past experience with the Technomate will give a clear picture at 20% quality but any slight fluctuation below this will result in broken picture and sound and finally no signal received (which I get with Nilesat and Arabsat when it gets cloudy) The above are my readings, observations and views, from my location with my set up. I expect others might have different views/suggestions. regards Redmund. Last edited by RedAltoGL; 20-07-2005 at 12:05 AM | ||
| | #8 | |||
| Regular Member Join Date: 22-04-2005
My System: Technomate 1500cl+, with an 80cm Dish and a Moteck SG-2100 H to H motor |
i have smw link but what figure is my lnb skew? i couldnt see it marked. Dinger | |||
| | #9 | ||
My System: LNB, Dish, Motor, Cable, Receivers all taken down and donated to a newbie. | Hi Dinger Skew is Polarization Angle on the SMW link. regards Redmund PS About 14 degrees clockwise from the vertical looking into the dish, do you agree? Red PPS Just noticed that you are motorised, ignore my above PS which was for a fixed dish looking at 13 east from your location. Your LNB must be upright at your south satellite. The motor will turn your dish and consequently the dish face and LNB will be square on to the signals coming down from the satellite. Red Last edited by RedAltoGL; 20-07-2005 at 12:38 AM | ||
| | #10 | |||
Dinger | |||
| | #11 | |||
Red | |||
| | #12 | |||
Red PS Try h**p://satlex.de/en/azel_calc-first_1.html Red Last edited by RedAltoGL; 20-07-2005 at 12:44 AM | |||
| | #13 | |||
Dinger | |||
| | #14 | ||
| I was being a bit flippant when I mentioned 'twist' but thanks anyway. I'm going to run a different dish on a pole in the front garden and see what that does, then swap the LNB's out. All about isolation innit | ||
| | #15 | |||
Woo-hooooooo. Fixed it. Very pleased with myself! | |||
| | #16 | ||
| Nasty Dish Obsession Join Date: 01-06-2004 Location: Oxfordshire
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | So what did it turn out to be in the end. ? We're all dying to know now L. | ||
| | #17 | |||
But one problem…Multivision. It was fine when I checked it after install, but yesterday evening, the signal strength was pulsing up and down from 10% up to 80% via a load of percentages on the way. Only affected this transponder. Was fine again this morning, but I suspect it will go again this evening. I wondered if it was the DECT phone causing interference but it wasn't that. Alignment seems to be good for absolutely everything else now. Any ideas? Finally. I have a Technomate TM5000 DAPCI. How do I find out if it's patched? I'm currently using a goldcard (as per Analoguesat on a different thread) and a red viaccess cam. | |||
Similar Threads | ||||
| Hotbird and Eutelsat in Cyprus | Uk2cyp | Digital systems | 5 | 26-11-2004 09:16 PM |
| Sky+ recording problems | pjb | Sky+ and PVR Systems | 4 | 17-06-2004 11:46 AM |
| Few people seek help for sex problems | net1 | The Meeting Place | 0 | 22-08-2003 08:11 PM |
| Problems... Help ! | iwearflares | Analogue systems | 2 | 11-08-2003 08:01 AM |
| Serb Channels debut on seventh HOTBIRD Platform | net1 | Daily Satellite and Broadcast industry News | 0 | 08-07-2003 08:45 PM |
