setting for hotbird (no signal quality received) | |
| Member Join Date: 19-07-2005 Location: Birmingham
My System: to be done later | Hello, I'm trying to get channels on Hotbird sat. I pointed dish to the Satellite with Network ID 013e. I received a signal stength of 67% and there was no signal quality (signal quality = 0%) I tried repositioning the the dish many times but I always get signal quality = 0% even for other satellites. I use technomate TM4100D digital satellite receiver, 80 Cm satellite dish and Blue Line single universal digital LNB. Could any one let me know did I do any thing wrong? Any suggestion | ||
| Making the best of small resources Join Date: 25-06-2005 Location: London, UK
My System: FTE IRD FTA Sat Box :: Pace Sky Digibox :: Sky 2 Mix Sub :: 60cm Black Mesh Dish :: OnDigital Box (Mediamaster) :: Humax PVR 8000T ![]() Best newbie geek pit /age ratio 2005 | Maybe the completely obvious, but was it definetly aligned properly? | ||
| Regular Member Join Date: 19-07-2005 Location: Norfolk, UK
My System: Technomate 1500 CI+ Super and Sky Digital | Signal strength is a measure of the connection between the receiver and lnb, the important one is signal quality. I get 13e with the silly little Lidl/Comag Porty dish but it took me a while to get the hang of it. I learned by first pointing at Astra (Sky) 28.2 in the same direction as my Sky dish (or a neighbour if you don't have Sky) and tuning that in then I ventured to 19 and 13e which are quite powerful. Just keep at it, I can go between 19e and 13e in seconds now. ![]() Hmm a bigger dish and motorisation would be nice. Last edited by Dennis on Sea; 20-07-2005 at 08:03 PM | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You also have to make sure that the default transponder for the satellite is a digital one and still available, check it HERE
__________________ | |||
| | #5 | ||
My System: to be done later | Thanks everyone, yes I checked the transponder setting and even when I try to get Astra(sky) I get no luck the signal strength is always 0 no matter what direction or a satellite I chose, I think it is something more than positioning the dish correctly but not sure what | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Do you have the LNB set as a universal in the receiver setup, have you checked the connections on both ends of the cable?
Similar Threads | ||||
| Quality signal problems | burnet01 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 26 | 14-02-2006 12:07 PM |
| Digital Terrestrial (Freeview) TV reception, Aerials! | spiney | Members' input on FAQ and How To's | 0 | 09-06-2005 03:05 PM |
| Skystar 2 Signal 50%, quality 50% - but no real signal | zoltiz | Satellite PC Card Systems & Internet by Satellite | 4 | 21-12-2003 08:17 PM |
| What is the minimum quality signal percent to be able t owatch a digital channel? | ynot62 | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 3 | 10-12-2003 09:49 AM |
| No satellite signal being received | jpmoore40 | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 30 | 03-12-2003 09:05 PM |
