prime focus & offset
Old 21-07-2005   #1
amxson's Avatar
My System: I have one 12ft dish mesh one 6ft solid and a 90cm ku band .My computer system with p4 , receivers eurostar, coship,and starsat
Smile prime focus & offset
In prime focus dish could I get ku band signals ?
For getting signal strength of 3m kuband dish what type of prime focus to be used. If it is available on a mesh dish .
amxson is offline   Reply With Quote
Old 21-07-2005   #2
Yes, you can get ku-band on a prime focus dish. It could be mesh or solid.
The size of dish required depends upon the quality of the make and the sensitivity of the LNB. I think a solid dish has slightly better gain than a mesh dish so you might get away with one slightly smaller than 3m - but not a lot smaller.
007.4 is offline   Reply With Quote
focus, offset, prime
[IMG] code is Off
Similar Threads
Prime Focus or Offset Dish? Kidson DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 20-06-2006 07:04 PM
1.5m Offset Vs 1.8m Prime Focus ? tux233 DISH SETUP: Single sat, Multi-Sat & Motorised systems 18 20-11-2005 12:26 PM
Offset or Prime Focus?? Indasol Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 2 03-02-2004 09:04 PM
single feedhorn for 1.80m Channel Master Prime Focus jacqfranc DISH SETUP: Single sat, Multi-Sat & Motorised systems 3 02-02-2004 11:05 AM
Prime focus dish with a H-H motor? Martie DISH SETUP: Single sat, Multi-Sat & Motorised systems 3 09-01-2004 08:02 AM
