Trying to setup Norwegian Viasat in Scotland
Old 23-07-2005   #1
My System: 1.2m Dish Twin LNB's Legit Norwegian Viasat subscription Thomson Box
Unhappy Trying to setup Norwegian Viasat in Scotland
My Wife is and kids have Norwegian as a 1st language. I have a legitimate subscription to Norwegian Viasat, have just moved to Scotland and am trying to get it working.
I have a 1.2 m dish with twin LNB's, a Thomson settop box(came with subscription) and have borrowed a Satlook Micro+ meter.
I'm an absolute newbie and basically only know what I've read on these forums and other internet pages:
I need Thor 1 deg W. and Sirius 5 deg E. I have managed to tune into Sirius an get a lock, although the signal strength is not good and a satellite at 7 deg E. keeps bleeding over my signal.
I can't find Thor at all, which concerns me as everyone says that is the one with the strong signal.
I am unable to do a network search on the set-top box as I am not getting a strong network signal, although when I do an open search, I get ukranian tv and a lot of Dutch Channels, which could come from the 7 deg signal?
I have taken note of the transponder signals to hunt for from another link on this site 11766H 27500; 11189V 2142; 11421 241501; 12303 25548, but need to do some reading on how to get them stored in the Meter.
I have read and read and read, and tried and tried and tried to get this to work.
if anyone can help me, I will be eternally grateful. If I need to drop to 1 LNB, reduced channels etc. I will, but I will settle for anything just now.
Thanks in advance
Andrew
ac163601 is offline   Reply With Quote
Old 23-07-2005   #2
Site administrator
Analoguesat's Avatar
The variuos signals on 5E and 1W are transmitted on a number of different tarnsmission footprints. Peak your dish up using the 5E ukrainian signals on 11766 - they are nice and strong
For Thor 1W try the transponder that transmits the BBC World channel. The Dutch channels must be coming off 19E!
Old 23-07-2005   #3
Thanks very much for the quick reply!
As before, I apologise for my ignorance, but I'm hunting for the Satellites using a 'match' function on the meter as it beeps when I get a lock.
The only thing I know how to do, is change the frequency on what I'm looking for. I've just been checking and the meter doesn't let me store a transponder manually. I need to lock in to it first and then save it. How daft is that?
What frequency are the BBC Channels on?
Cheers
Andrew
Old 23-07-2005   #4
Now I'm even more confused. I just checked the channel list I'm getting, and as far as I can tell it is on 5 deg East: http://www.satmania.com/eng/satchann...covery_channel
But, It appears to be on Sirius 2, whereas, I need Viasat which is on Sirius 3!!!!
Both show as 5 deg East.
http://www.satmania.com/eng/satchannels/5_0e
Help........?
Old 24-07-2005   #5
Dennis on Sea's Avatar
My System: Technomate 1500 CI+ Super and Sky Digital
http://www.nsab-sirius.com/images/img_s3_bss_nordic.gif
Even with a 120cm dish you may struggle to get Viasat on the Nordic beam of Sirius 3 in Scotland according to the Sirius website. I'm sure Analoguesat can confirm or not, he knows far more than me!
Dennis on Sea is offline   Reply With Quote
Old 24-07-2005   #6
My System: 105 cm motor dish with 75E to 45 W - Openbox 820 CI
M8 give it a try here :
http://www.kingofsat.net/de/satellites.php
Pretty self explaning ;-) and gives you a good overview of the two sats and the frequencies and Transponders of channels.
Regards
Claasi
claasi is offline   Reply With Quote
Old 24-07-2005   #7
Site administrator
Sirius 3 is very weak here in south Scotland, I can just get some of the better transponders in good weather on my 1m dish.
(ive never got anything off Thor 3 at all...)
Old 24-07-2005   #8
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
That's the way it goes sometimes as we know. I can get a decent sig from Thor3 in the early mornings from here. Just nipping the edge of the East Europe beam as you can see
L.
Trying to setup Norwegian Viasat in Scotland-thor-jpg
Lancelot is offline   Reply With Quote
Old 25-07-2005   #9
Norm's Avatar
My System: Channel Master 1.2m motorised, V Box, Technomate 1500ci.
Sirius 3 has been OK in Aberdeen with a 1.2 metre dish - as you can see it's right on the edge of the footprint. So I guess it all depends on where in Scotland you are located as to how much success you're likely to have.
Satellites.co.uk F1 SupaLiga 2009 - CHAMPION
UniSat Champions League 2008/2009 - CHAMPION
Norm is offline   Reply With Quote
Old 25-07-2005   #10
Folks I can hardly believe that you face so much problems to receive Serius 3. Are your dishes setup properly ? Usually these official footprints are not really exact. And if it would be true in case of Sirius 3 the last EIRP is mentioned with 44 and that has a recommendation of 90 cm according to this:
http://www.satlex.net/en/eirp_values.html
Besides if the footprint is always that exact I guess we wouldn't pick up Nile sat at all since that footprint is much more south.
BBC on 2D for me, according to the footprint, I shouldn't be able to receive with 1,2 meter dish at all.
But you guy's should know better I guess what reception is like but perhaps the one or the other might give it a try to adjust his dish again ;-)
Claasi
Old 25-07-2005   #11
Site administrator
My 1m dish is set up just dandy Ive had the free Baltic channels off it on occasions, but the first hint of rainor heavy rain and the signals disappear.. Not bothered any longer though - that dish is being redeployed to 26E instead when Ive got a few minutes.
Old 25-07-2005   #12
Don't forget to turn the LNB tilt (skew) if you have a fixed system. This is quite importend and lots of folks forget about this.
norwegian, scotland, setup, viasat
[IMG] code is Off
Similar Threads
Official TD Image Llew Triple Dragon 29 13-12-2007 04:56 PM
Mobile dish setup info required bebeto94 DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 24-04-2006 11:38 AM
Viasat Explorer to launch in Eastern Europe net1 Daily Satellite and Broadcast industry News 1 03-08-2005 07:26 PM
Scotland Vs Lithuania (Saturday) Dean131 What's on listings 0 07-10-2003 05:13 PM
Humax/Diseqc 1.2 setup? steford1 DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 28-09-2003 08:29 PM
