Help needed on Channel Master 1.2 dish | |
| Specialist Contributor Join Date: 01-01-2000
I'm installing a Channel Master 1.2m offset dish + Polar Mount in a new location. Looking for the following information. 1/ I found an old Channel Master document on the web which implies the offset is 22.6° - can anyone confirm this figure? 2/ I found a help sheet on setting the declination - see attachment. But the instuctions look wrong. If you look at the attachment it says the example shown is set for 32° latitude based on the position of the back edge of the top plate. But based on my own measurements it appears the example is set for about 48° latitude - seems the setting should be based on the lipped edge of the top plate. Anyone has any views of which is correct? | ||
| Regular Member Join Date: 18-11-2004 Location: Belfast, Northern Ireland
My System: Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn. | My measurement is taken from the top lip off the plate.These mounts are quite tricky to set up on the arc! | ||
| Thanks for your reply, you seem to confirm my own calculations. I wonder why the Channel Master installation manual shows the wrong information. It looks an official document, although I don't have all the pages to confirm its source. Does anyone on the forum with a 1.2m Channel Master dish supplied from new have the official documentation supplied with the dish? | ||
| | #6 | ||
| There are various CM dishes of 1.2m, but the offset angle is uaually calculated from the latitude of the installation, plus the offset of the main reflector. Do you have the model number from the main dish reflector ? ( it will be embossed on the rear next to the CM markings ) If you are using the Gregorian antenna then there could well be a different setup to observe, but the manual diagram seems to show a standard receive only antenna plate.
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #8 | ||
| Likvid Thanks for that. I got that document before when I trawled the net but it's for the fixed AZ/EL mount, not the motorised polar mount. It is however the only document I've found that mentions the 22.6° (on page 8). But it is only a passing reference and it's only a guess on my part that this is the correct offset. Channel Hopper It says Part No. 3040646 & Mold No. 1.2M-1 on the rear if the dish. I am looking for the the offset of the main reflector. It is a standard offset dish, not a Gregorian (the dish looks like that shown in Likvid's PDF document). Also, thanks to another offer of help to which I've replied by PM. | ||
| | #9 | ||
| ASBO Club Member - Persona non grata Join Date: 30-07-2003 Location: Stockholm, Sweden
| The offset is 22.6 degrees. I have installed this dish in France for a client this summer from Andrew, it's the same dish but Andrew bought Channel Master, Channel Master doesn't exist anymore. It's Andrew these days. And yes, the offset angle is 22.6 and it is correct as i have worked with this dish myself. | ||
Similar Threads | ||||
| single feedhorn for 1.80m Channel Master Prime Focus | jacqfranc | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 02-02-2004 11:05 AM |
| Comparing Channel Master 2.4, prodelin 2.4 & Patriot 2.4 | ynot62 | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 15 | 04-01-2004 06:44 AM |
| Transponder update 20/09/03 | Satdude | Transponders & channels | 0 | 20-09-2003 09:26 PM |
| Transponder update 21/08/03 | Satdude | Transponders & channels | 0 | 21-08-2003 06:25 PM |
| Channel Master USA in Deep Trouble | Channel Hopper | Daily Satellite and Broadcast industry News | 0 | 18-08-2003 06:51 PM |
