do these figures look right
Thread Tools Display Modes
Old 28-10-2005   #1
Hi all
Just a quick question, I'm trying to locate hotbird 13 east, I've read one of teh sticky posts, can some one look at these figures and see if they are correct:-
my location (according to Multimap - SE14 London)
Lat: 51:28:44N (51.479) Lon: 0:02:29W (-0.0414) (can some one tell me what the brackets are?????)
13e (hotbird) minus 2.29w = 13 + 2.29 =15.29e
So I need to be pointing my sat at 15.29 degrees to pick up Hotbird 13.
The elevation on my motor should be set to 51.28 degress (my Latitude)
One further question, okay I've set my motor to an elevation of 51.29 degrees, but the actual dish needs to elevated to a position aswell, how do i work this out.
thanks all
thuynh7 is offline   Reply With Quote
Old 28-10-2005   #2
Jeff_19341
Posts: n/a
The numbers in brackets are the decimal of your lat and long and these are the figures that you use for setting up your gear.
The dish latitude should be 51.5 (nearest to 51.479) or elevation 0f 90-latitude = 38.5.
Which motor are you useing?
The look angle for Hotbird from your location is 163degrees the skew of the LNB is 10degrees clockwise looking into the dish.
Your long is 0 (zero) for all intents and purposes.
The satellite position ie Hotbird at 13 east or Hispasat at 30west is it's position in space over the equator. Your look angle differs because of your location on the planet.
Old 28-10-2005   #3
Hi thanks for the reply
Can you explain how you got 163 degrees? Is this 163 degrees of North or south?
The motor I'm using is an old SM2UNI
Old 28-10-2005   #4
Jeff_19341
Posts: n/a
Look angles from this link http://satlex.de/en/azel_calc-first_1.html
North is zero, East is 90, South is 180 and west is 270.
Just a question, were you taught Geography at school (For a survey that I am doing)?
Hence 163 degrees is 17 degrees east of south.
Old 28-10-2005   #5
Thumbs up
Quality site, man! Thanks, just what I have been looking for.
thanks.
jpmm is offline   Reply With Quote
Old 28-10-2005   #6
Hi
Was taught geography at school but not this sort of stuff.
thanks for directing me to that site.
But can you explain this:-
re: The dish latitude should be 51.5 (nearest to 51.479) or elevation 0f 90-latitude = 38.5.
does this mead that the dish should be tilted 51.5 degrees or 38.5 degrees
regards
Old 28-10-2005   #7
rolfw's Avatar
Those figures do not apply to the dish, but to the motor, your motor may have both an elevation scale and also a lattitude scale, or just one of them, whivhever you have use the correct figure from your post again.
The dish setting is called the declination and there is usually a calculation for it in the motor handbook.
__________________
Rolf
Donate
Old 28-10-2005   #8
Jeff_19341
Posts: n/a
Ref "The dish latitude should be 51.5 (nearest to 51.479) or elevation 0f 90-latitude = 38.5."
Very sorry I should have said The Motor latitude should be 51.5 etc
I should not have been drinking that glass of British fortified wine whilst I made that post
Old 28-10-2005   #9
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
He was pulling your leg
North is zero, south is 180. East is 90, west is 270 degrees.
mhku is offline   Reply With Quote
Old 29-10-2005   #10
Jeff_19341
Posts: n/a
@ mhku
Me no understand your last post.
[IMG] code is Off
Forum Jump
Similar Threads
Freeview viewing figures soar net1 Daily Satellite and Broadcast industry News 0 20-09-2004 07:41 PM
Millions Press Red Button net1 Daily Satellite and Broadcast industry News 0 20-08-2004 07:35 PM
International News 3rd December net1 Daily Satellite and Broadcast industry News 0 03-12-2003 09:01 PM
Receiver thresholds gcohen Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 1 03-10-2003 05:42 PM
Freeview hits 2m mark net1 Terrestrial Television, Digital and Analogue 0 29-09-2003 06:19 PM
