3 inch pole mount recommendation | |
| Member Join Date: 30-09-2005 Location: UK
My System: 1.2 Metre Dish, Channel Master H-H mount, ACME Actuator, Skystar2, PIII-600MHz |
Hi, I need a 3 inch pole to mount a motorised dish on, approx 1.2 metre dish, standing on the ground. I noticed that satellite superstore sell something for around 135 quid, which is always one option. Can I obtain/make a stand for less than that? Are there any cheaper ones, or is that what I can expect to pay? thanks, -biff. | ||
| Member Join Date: 08-10-2005 Location: North
My System: None | Look at www.cpc.co.uk Their catalogue no SE00386 Ground stand for dishes 1.0 to 1.3m £27.72 (ex vat) If your order is over £35 (excl vat) delivery is free. Usually takes 2 days. I've been dealing with CPC for about 4 years and absolutely no problem at all. | ||
| Part Timer Join Date: 06-10-2005 Location: that would be telling
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | can you get hold of some scaffold tube if so use that i just mounted a 85cm one in my back yard.don't make the same mistake as me i left over 71/2 ft out of the ground way to much at this moment i am building it up in a concrete block so for £55 in concrete.it was fixed a treat i just had i slight wobble on the pole i used 2x6ft tubes 2x3ft tube joined the 3ft to the 6ft and made an cross with two clamps put in the ground covered in concrete got it pum.when dry add the other 6ft with a sleeve worked a treat apart from that f675king wobble sorted tomorrow and then refit the dish i will stick photo on tomorrow | ||
| | #4 | |||
| | #5 | |||
I'll be looking forward to that photo... cheers, -biff. | |||
Similar Threads | ||||
| Pole shift | lejizz | Einstein's Alcove | 25 | 14-02-2005 04:39 PM |
| Getting the pole straight | martinw01908 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 6 | 13-05-2004 12:21 AM |
| Girl finds two-inch penis on Incredible Hulk doll | net1 | The Meeting Place | 1 | 10-07-2003 06:17 PM |
