total novice to sateliteInformation exchange on LNBs, Single satellite, motorised and multi-satellite systems. DiSEqC switches, positioners, motors, actuators, dish-alignment etc. | |
| | #27 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | The technomate when patched will give you the same as a Dragon cam will. The Digitalb package is in conax and on 16E, but you will need to purchase a card for it from a supplier. As mentioned conax packages are secure for the moment. Rgds L. | ||
| | #29 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | UniversalSAtelliteLocatingSystem is an extension of the DigitalsatelliteeqquipmentControl system, but requires a compatible motor and receiver, there is little difference between the two once you have the satellites set up. | ||
| | #30 | ||
| Member Join Date: 01-03-2006 Location: newcastle
My System: new | i have a few issues with my setup . i have my pole perfectly straight. my latitude set for my location of 55 deg. and sat pointing tru south . i have found thor for referance got 96 signal and 80 qlty . i can pick up 7w nilesat ,5w atlantic. all with good strength and qlty but nothing else in the belt. one thing i am comfused is about is my declination what should i set this too. also in my tachomate i have a menu that has all cam names eg viaacces, betacrypt,nagravison, quite a few listed with alphanumeric digits under them what are these for as they can be edited . is this the enbeded cam if so where cani get codes from thanks g | ||
| | #31 | ||
| Regular Member Join Date: 16-10-2005 Location: Barnet, North London
My System: Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e | that is the patch menu to input keys i suggest doing a google for a l s a t | ||
| | #33 | ||
My System: new | i have a few issues with my setup . i have my pole perfectly straight. my latitude set for my location of 55 deg. and sat pointing tru south . i have found thor for referance got 96 signal and 80 qlty . i can pick up 7w nilesat ,5w atlantic. all with good strength and qlty but nothing else in the belt. one thing i am comfused is about is my declination what should i set this too. | ||
| | #34 | ||
My System: new | right just gone to lyngsat to check if channels match what ive got depending on satelite and my dish is lined up to thor wich i think its thor but pick up all channels on hispasat . how do i know i got right satelite. have i lined up to hispasat on my thor channels by mistake | ||
| | #35 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | If you are scanning channels which are to be found on Hispasat and you can actually view them, then your dish is pointing at Hispasat. The quickest way to check a satellite, is to scan a predetermined transponder with FTA channels and look to see if the scan finds them. | ||
| | #37 | ||
My System: new | bit confused on tachomate ive set it to thor but picking up hispasat channels on what i think is thor . how do i know if i am focusing on the right sat. or will the receiver scan a satelite weather it is the sat i am looking for ie there is no way of finding what sat i am looking at. or should i jusy nudge my sat 30 deg east | ||
| novice, satélite, total |
Similar Threads | ||||
| Help!- Total Novice requires pointers | 1971mikes | Digital systems | 2 | 07-09-2004 01:19 PM |
| Transponder update 14/07/03 | Satdude | Transponders & channels | 0 | 14-07-2003 11:26 PM |
| Spain's Supreme Court orders Canal Satelite compensation | net1 | Daily Satellite and Broadcast industry News | 0 | 25-06-2003 09:04 PM |
| Spanish government to pay Canal Satelite, rules court | net1 | Daily Satellite and Broadcast industry News | 0 | 16-06-2003 09:30 PM |
| Help for a total Novice | Gizmo2000 | Cards & Programmers General | 4 | 18-03-2003 06:50 PM |
