total novice to satelite
Old 01-03-2006   #1
My System: new
can anyone recomend a good setup to watch spanish tv or s american tv in spanish language . what i would need and good place to buy from and what is possible to receive as i am in the north esat of england
thanks
smokeyUK is offline   Reply With Quote
Old 01-03-2006   #2
spiney's Avatar
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
For free Spanish channels in UK, see: www.lyngsat.com/freetv/Spain.html .
Astra1 requires only a small dish, Hotbird slightly larger, Hispasat larger still.
(for some idea of dish size, try googling for images of "astra1 footprint", then "hotbird", then "hispasat").
Most inexpensive free-to-air sat receivers will do, but channels do change, to save constant manual updating a "blind scan" type receiver is useful.
A conditional access receiver may allow card viewing of (some) pay channels, depending on how you "get" the card.
A fixed single dish with "monobloc" lnb antenna will get astra1/hotbird, but for receiving 3 or more satellites a motorised dish is really required!
(for suppliers, see our links pages!).
spiney is offline   Reply With Quote
Old 01-03-2006   #3
My System: new
thanks for the info i was looking at a motorised 80cm dish that should do the job i take it
Old 01-03-2006   #4
spiney's Avatar
80 cm is ok for astra1/hotbird, but I'm not sure about Hispasat, you really need advice from other people getting that in your area.
(Unfortunately, the Hispa beams very rapidly "fall off", going towards north and east, across the UK).
Old 02-03-2006   #5
AMCRAZEEEABOUTHOTBIRDS
wallwok's Avatar
My System: technomate 1000D patched Motor Dish 80cm xp athlon
I am 50 miles north of you and I have a motoised 80cm dish, hispasat is perfect and all others around to 53e.
wallwok is offline   Reply With Quote
Old 04-03-2006   #6
My System: new
no probs u will be seting up sat on the weekiend any probs i know where to come cheers
Old 04-03-2006   #7
My System: new
ok ive got myself a 80cm dish with DiSEqC 1.0 1.2 2.0 & 1.3/USALS with a 0.2 lnb . what is the best value for money receiver avialable with cam slots and what is the best cam to get. i am mostly interested in then hispasat channels
Old 04-03-2006   #8
wod
wod's Avatar
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+
well technomate recievers are good i've got the 1500 ci one and would say go for a dragon cam
Old 04-03-2006   #9
My System: new
whats the current going price for those units
Old 04-03-2006   #10
Oily's Avatar
My System: Satellite=Motorized Triax 88cm&a DM800HD.Sky,only because of its free broadband! Comp=3.2 AMD 64bit,1 gig of Corsair XMS,Radeon X800 Pro,NEO Platinium mobo
Around the £100 mark for a 1500CI+,don't know about the cam
Oily is offline   Reply With Quote
Old 04-03-2006   #11
wod
wod's Avatar
the dragon cams are about 70 ish but worth it
Old 05-03-2006   #12
My System: new
also what can be picked up using the sky minidish as to channels also can a universal lnb be used with the didgy box runing 2 receivers
Old 05-03-2006   #13
rolfw's Avatar
Real name: Rolf
If you leave the minidish pointing at Astra 28.2 (where Sky UK is), then there is really nothing useful there for a non-Sky receiver and the dish is too small for an offset LNB for a second satellite. You would need a larger dish with perhaps a couple of offset LNBs or a separate dish with a motor.
Rolf
Old 06-03-2006   #14
My System: new
wich sateliite is best to line up as a reference point when setting a 80cm motorised system i am in north east england on coast
Old 06-03-2006   #15
Sir Bronking's Avatar
My System: medion pentium4 3.2ghz progdvb skystar2 rev2.3 1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
Sir Bronking - First Commander of the Idiot Guide Order Thread Hyjack Fyghter squad
thor 1w is usually fav
patience is not a virtue, its a godsend.a picture is worth a thousand words
polite notice: do not hijack threads,do not double post,
search and ye shall find (before you ask)
Sir Bronking is offline   Reply With Quote
Old 06-03-2006   #16
My System: new
right ive bought a tachomate 1500+ receiver how are these to setup
Old 07-03-2006   #17
ive just inputted technomate 1500+ into search facility and came up with 83 pages of threads.
so i guess that mean's there is plenty of info on this forum if your willing to look
Old 07-03-2006   #18
My System: new
thanks for that good read / whats the difference between a patched unit and normal unit ?
Old 07-03-2006   #19
rolfw's Avatar
Real name: Rolf
The patched unit will enable the viewing of some encrypted channels without card or CAM.
Rolf
Old 11-03-2006   #20
hello smokeyUK,
when you are new at sat messing, try cheap stuff such as a mini dish
I take a mini dish away with me when I work away on nights
I set up a 12v supply to my receiver (dreambox500s) and mini dvd player, from cig lighter in van.
I put mini dish on back seat and with all windows shut have had excellent results on Hispasat 30w,Astra1 19E,Hotbird 13E.
When you practice it only takes 2mins to find these Sats, I've done this in Lockerbie, Scotland to Reading area.
mickeymegabyte is offline   Reply With Quote
Old 31-03-2006   #21
My System: new
right i have installed satelite and tachomate 1500 but have few ??? the tachomate has conax embeded cam . what does that do . also wich sytem is beter to use usal or disq mine motor uses both but chich is best . also is there anywhay of getting rid of my sky digy box and use tacho unit . ive tried my subcription card on tacho but no joy
thanks
Old 31-03-2006   #22
wod
wod's Avatar
the technomate 1500 doesn't have conax embedded , its just got a card reader that will read any of the encryptions except sky uk cards
for your sky uk card to work you will need a dragon cam and to put the sky card back in the sky digibox for it to keep getting the keep alive signal
Old 01-04-2006   #23
My System: new
ive been told by the company i purchsed unit from that has conax patched cam .just wanted to know what it does
Old 01-04-2006   #24
wod
wod's Avatar
arh they patched the reciever then in that case it will open any channels in conax encryption or allow you to use conax card in it
Old 01-04-2006   #25
Lancelot's Avatar
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W
...And thou were the truest friend to thy lover that ever bestrad horse..."
Yes but, only if the keys are known.
Currently there aren't any public keys for any conax package.
L
Support our Advertisers
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
novice, satélite, total
[IMG] code is Off
Similar Threads
Help!- Total Novice requires pointers 1971mikes Digital systems 2 07-09-2004 01:19 PM
Transponder update 14/07/03 Satdude Transponders & channels 0 14-07-2003 11:26 PM
Spain's Supreme Court orders Canal Satelite compensation net1 Daily Satellite and Broadcast industry News 0 25-06-2003 09:04 PM
Spanish government to pay Canal Satelite, rules court net1 Daily Satellite and Broadcast industry News 0 16-06-2003 09:30 PM
Help for a total Novice Gizmo2000 Cards & Programmers General 4 18-03-2003 06:50 PM
