Newb motorised setup woes!
Old 11-03-2006   #26
My System: none yet
C.C...C...CC...CC.C..cold Frostbite stopped play, still no joy I'm affraid. had the dish off again. noticed the lnb was a smidge off centre on the bracket, reset and tried again I cant beleive I'm getting absolutely nothing not even a bad signal. I'd hate to admit defeat, and get someone in. try again tommorrow if weather allows.
hacksawbob is offline   Reply With Quote
Old 11-03-2006   #27
rolfw's Avatar
Real name: Rolf
The voltage at the motor/lnb should be a maximum of 19 volts, if you are reading 80v, there is something seriously wrong.
Rolf
Old 16-03-2006   #28
My System: none yet
Hi guys, I'm back I'm affraid. False alarm with the voltage my meter needed a battery change. Weather hasn't been up to much lately as I'm sure your aware, I have tried sweeping the dish back and forth around the due south mark at varying dish declinations looking for thor. Not a saussage. any ideas? I am at a loss where to go with this. I've remade all the fconnectors SURELY the only thing left is the lnb, dont these go wrong?
Old 16-03-2006   #29
rolfw's Avatar
Real name: Rolf
Yes the LNB could be faulty, but the most common mistake I see is that members tend to point the dish too high.
Rolf
Old 16-03-2006   #30
My System: none yet
Hi rolf, I take it form the earlier post that the dish needs to be at about 10 degs off perpendicular, I have measured this with a spirit level (with an angle finder) which equates to 27 degs on the dish bracket. Am I right in thinking that I will not get ANY signal unless I'm bang on the satellite? how much overspill do you get either way? would moving the lnb one cm be the difference between some signal and absolutely nothing? I'm just trying to guage how much I need to be mong the dish by.
Old 16-03-2006   #31
rolfw's Avatar
Real name: Rolf
Yes, you certainly need to be pretty close, not really sure how the difference between hit and miss would equate to movement at the end of the boom arm though.
That 27 degrees sounds a bit high.
Rolf
Old 16-03-2006   #32
My System: none yet
YEs it says 27 on the dish bracket but the 'real' measured tilt from vertical is 10 degs even though the scale on the bracket says 27!
Old 16-03-2006   #33
Jeff_19341
Posts: n/a
Hi
You do have an offset dish hence difference in numbers.
Declination for your neck of the woods about 7 degrees set the dish angle scale to about 29 -7 = 22.
Jeff
Old 16-03-2006   #34
My System: none yet
where do you get the 29 figure from?
Old 16-03-2006   #35
rolfw's Avatar
Real name: Rolf
29 degrees (or thereabouts) is the elevation from your location for the top of your arc.
Rolf
Old 17-03-2006   #36
Jeff_19341
Posts: n/a
Rolf is correct.
Use Calculator for azimuth and elevation angle
this calculator .
Jeff
Old 17-03-2006   #37
Satellite Whore
longstockings's Avatar
My System: Technomate 1500 CI+ 80cm Polycarbnate Dish 0.3db Universal LNB Moteck Digipower Motor
That calculator is absolutely brilliant
Thanks for posting such a great link
I'm of the opinion that the dish is set to high which is why nothing can be found
longstockings is offline   Reply With Quote
Old 17-03-2006   #38
Jeff_19341
Posts: n/a
Usefull little tool Longstockings, glad to be of use. I also agree the dish is pointing too high. As they say "a miss is as good as a mile" , in trying to pick up a satellite located about 40000kms away out in space.
Jeff
Old 19-03-2006   #39
My System: fortec star motorized system
i use a post level used for fencing this is simply a piece of plastic with 3 levels and two sides on only cost £3-4
bishbosh is offline   Reply With Quote
motorised, newb, setup, woes
[IMG] code is Off
Similar Threads
Mobile dish setup info required bebeto94 DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 24-04-2006 11:38 AM
tracking that Arc? Setup Woes mick2me DISH SETUP: Single sat, Multi-Sat & Motorised systems 16 06-10-2005 01:59 AM
Humax/Diseqc 1.2 setup? steford1 DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 28-09-2003 08:29 PM
Multiple Lnb's on Motorised system ? Rob T DISH SETUP: Single sat, Multi-Sat & Motorised systems 4 04-09-2003 09:18 PM
Motorised system Sab DISH SETUP: Single sat, Multi-Sat & Motorised systems 2 27-08-2003 10:35 PM
