best way to mount dish | |
| Member Join Date: 25-02-2004 Location: n.ireland
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card |
i have bought a motorised system which i want to setup i have all the gear sitting but i have a little problem i need to setup my dish so it can face south but my house is a terraced house (houses joined on both ends) and the only walls i could mount the dish on face east and west so i cant mount it there as it would not be able to move freely through its arc. i thought about mounting it in the garden but there is nothing readily available to do so so what i was wonderin was can i easily build something to mount it on and what i need to consider in doing so. bearing in mind that im not a builder is there something simple i can do or do i need to get a builder. hope you can help thanks | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | If you have a good line of sight in the garden for the arc, then simply a pole mounted in concrete should do.
__________________ | |||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | it would need to be at least 2m high so i think a pole that length may sway about in the wind | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Not necessarily, a scaffold pole will keep pretty stable at that height and a 3 inch mast will be even better.
| | #5 | ||
My System: 1m ? dish pole mounted in back garden, bigsat hh motor mount, 0.2db universal single lnb, technomate 1000c1, viaccess 2.5 cam, 1yr art subs card | ok thanks for your help but where could i go about getting a 3" mast and is it expensive. thanks again | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | What size dish are you going to use fersey, if it is 90cm or less, then a scaffold pole will be fine.
| | #7 | |||
| Regular Member Join Date: 28-01-2006 Location: Cheshire
My System: Sky+HD Astra+Hotbird FTA on 60 cm dish | Local streetlighting contractor may have some scrap lighting columns that are 76mm in diameter,you can either cut the wide base off or keep it on for some extra stability. J
