Every install picture I find | |
| Emperor born of a peasant Join Date: 31-05-2006 Location: Hull/East Yorkshire - Lat 53.769, Long -0.369
My System: Technomate 1500CI+ with Gilbertini 1m dish, MTI quad lnb, Dragon cam Cerebro card, Dynamite programmer, Skystar2, Full Bouquet Art Sports |
Suggests I have fitted my motor upside down http://www.satalogue.com/section4/images/mount.jpg If i have fitted it upside down well what can I say............. it works | ||
My System: Technomate 1500CI+ with Gilbertini 1m dish, MTI quad lnb, Dragon cam Cerebro card, Dynamite programmer, Skystar2, Full Bouquet Art Sports | That piccie is not of my install m8, thats one that I found on the web. My motor points downwards If you install the way shown, the rain can fall directly onto your coax F type connections, at least my way the F types have a little bit more shelter on the underside, and as I say it works both ways. I spent 2 days on my install m8, but it could have easily been done in only 1. At the start of day 2 I took my dish down & realligned the dish with the motor (which was well out). I took the advice of people on here & spent about 2 hours making sure my wall bracket was as perfect as I could get it. Even putting washers underneath 2 corners to offset for some uneven brickwork. I think a pole with 2 brackets would be far easier to install than this one that I used. http://www.cemsat.com/z/ebay/P/wallbracket-system.jpg | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorkshire, uk
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | those L shaped ones aren't so good as they can twist when the dish moves , a set of t&k brackets with a length of scaffold pole would have been better | ||
| | #6 | ||
My System: 90cm channel master, jaeger 1224 ,vantage x221tsci, skystar 2, diablo v2.3, setanta on 60cm minidish | usually the stab motors face up and the moteck ones face down i've noticed | ||
| | #7 | ||
| Member Join Date: 18-06-2006 Location: Edinburgh
My System: Triax TD88 dish w/ 4 LNBs (13E, 19E, 23.5E, 28E), Skystar2 2.6 with March beta drivers, Vista, DVBViewer. | Makes sense - you're always going to have the connectors on the underside, surely? | ||
| | #8 | |||
| DIY motorised Join Date: 10-11-2005 Location: Bedford
My System: 0.3dB Fortec Star lnb, 90cm Fortec Star dish, Silver Crest SL65 receiver, Stab HH90 motor... |
honest! | |||
| | #9 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Yes, as a general rule, the connectors are on the bottom of the motor. ![]() I have on more than one occasion, sorted out motorised setups and the first thing i had to do was put the motor the right way up.
__________________ | |||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I always thought that the first law of the hobbyist was: If it ain't broke, fix it until it is.
