Difference between H-H and polar mount
Thread Tools Display Modes
Old 24-06-2006   #1
kamaleon's Avatar
My System: skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
Hi folks...
Say, please, what is the *main* difference between a horizon-to-horizon mount and a polar mount? Is there one? or is this just a way of referring to the different kind of motors? I mean, a declination is a declination, a polar axis is a polar axis, innit? can they be different in one or another way?
Sorry if this is a dumb question, but i don't seem to find any "idiot's guide to the differences between H-H and polar mounts"
kamaleon is offline   Reply With Quote
Old 24-06-2006   #2
Amo Amas Amant Admin
Topper's Avatar
Well
A polar mount is engineered to describe the Clarke curve in the sky and will do so once set up correctly with or without a motor. In other words (once set up) you could have a pulley system to move from one sat to another, you can swing it by hand and it will still track the arc. An H to H mount is a lot lighter and works in a completely different way
Below is my Polar mount
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 24-06-2006   #3
kamaleon's Avatar
Originally Posted by Topper
An H to H mount is a lot lighter and works in a completely different way...
Ah!!! Just when you got me started, then you left me hangin...
please, by all means, do further explain, if you may
which completely different way is that?
Old 24-06-2006   #4
Nasty Dish Obsession
Lancelot's Avatar
My System: SS1. 3.4Ghz Dual Core P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H
...And thou were the truest friend to thy lover that ever bestrad horse..."
This is an H - H motor, where the motor angle sets the elevation as opposed to a polar mount where the mount sets the elevation and the motor just pushes the dish on the mount
Every install picture I find
Rgds
L.
__________________
I've got an inferiority complex, but it's not a very good one.
Lancelot is offline   Reply With Quote
Old 24-06-2006   #5
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
I have myself pondered on the differences between 'Polar' & 'HH', and could essentialy see none.
To track the Clarke belt you need to,
(1) rotate the dish about an inclined axis
(2) give the right amount of declination to the dish
(3) point it south at the top of the arc
Topper's wonderfully simple setup has an inclined axis, a way of adjusting the declination, and a means of moving it. Just like any HH mount. The differences being in the different engineering design features to get to the same end result.
I don't find my Yaeger 1224 HH mount particularly light when I am up the ladder
On further reflection, I would suggest that any tracking mount, that is aligned to the 'polar axis', ie: north/south, is by definition a 'Polar Mount'
__________________
Oldgeezer
johnsattuk is offline   Reply With Quote
Old 24-06-2006   #6
kamaleon's Avatar
Spot on Old geezer, exactly what me thought too...
A polar axis is a polar axis, whether it be "driven" by a diseqc motor or an attenuator... am I wrong?
I still wonder what Topper ment by "a completely different way"... ?
On this link:
_http://www.satsig.net/polar-mount-4.htm
they clearly refer to the moteck sg2100 as a polar mount
Old 24-06-2006   #7
Lancelot's Avatar
An attenuator really IS something different.
You mean a jack I think.
L.
__________________
Old 24-06-2006   #8
Oldgeezer
johnsattuk's Avatar
Or even an 'Actuator'
__________________
Oldgeezer
Old 24-06-2006   #9
Topper's Avatar
If you analyse the forces involved when the wind blows the dish the 'feedback' to the motor has a completely different path making the actuator method of moving the dish far stronger than the alternative H - H motor. That is what I meant, if you remove the motor on an H- H mount the dish falls on the floor and cannot track the arc if you disconnect the motor on my polar mount it can still track the arc whether by hand or strings. It is a totally mechanical tracking device driven by an electric motor or other. The H - H mount does not do anything without a motor hence my statement completely different.
__________________
Show Your Support
Thank you.
Old 24-06-2006   #10
Oldgeezer
johnsattuk's Avatar
Wind is probably the greatest force on the dish, and is often the cause of the demise, but because of the inclined axis, the dish itself exerts a force on the drive system when off centre, and this needs to be added/subtracted to the total loading. Gregorian dishes with a second reflector outboard giving an even heavier loading.
The feedback to the driving system is torque, how you resist that torque is a matter of design.
A linear actuator driving a dish, through a lever, may well be stronger than a Motec 2100, which only has a smallish plastic gear to resist the torque.
I have however seen a faily substantial actuator coupled to a dish via a flimsy lever which would fail long before the actuator did.
A Yeager 1224 HH motor has a substantial steel gear and worm, for which you pay.
The linear actuator no doubt will give the strongest solution from a cost point of view.
I don't see them as being different, just different design concepts and solutions to give the same end result.
__________________
Oldgeezer
Old 25-06-2006   #11
Topper's Avatar
Ok
Yes exactly the end result being one snaps the teeth of the nylon crown wheel in strong winds, the other doesn't
__________________
Show Your Support
Thank you.
Old 25-06-2006   #12
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
I think that the essential difference is that an H-H mount is directly driven off a gear and a polar mount has an actuator arm pushing the dish.
This difference is important in traditional motor drives where the H-H motor has a fixed number of pulses per degree moved and, because the actuator is pushing at a tangent, the number of pulses increases (or decreases - can't remember) as you move from maximum to minimum.
As Topper says, the biggest problem with H-H motors is broken gear teeth after high winds.
__________________
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 25-06-2006   #13
Oldgeezer
johnsattuk's Avatar
__________________
Oldgeezer
Old 25-06-2006   #14
Mod and septic resident
Channel Hopper's Avatar
Almost, the price of a decent polarmount system (including actuator drive)is usually far less than an Horizon to Horizon mount with similar accuracy.
H-H mounts do become far cheaper to manufacture when you are only dealing with 1m antennas, average weather, and dubious online guarantees. But they are almost unique in having the ability to move dishes using the LNB drive circuit and DiSEqC protocol.
__________________
Old 25-06-2006   #15
Oldgeezer
johnsattuk's Avatar
I'm sure cost is one of the biggest factors, if a manufacturer thought that enough people would pay a high enough price, we would have very robust Diseqc HH mounts. There are no technical or engineering difficulties.
There are also some Diseqc actuators appearing, best of both perhaps
Topper's mount with a Diseqc linear actuator, the ultimate
__________________
Oldgeezer
Old 25-06-2006   #16
kamaleon's Avatar
Jeezus, how many posts since me went to bed yesterday!
Yes, i actually ment a jack/actuator
i'll read the rest of it now
edit: ok have read
Right on fellas,
So, basically, to sum up, technically speaking, a H-H mount tracks the Clarke belt using the same type of declinations/elevations than a polar mount, and a polar mount is a more full-on setup being able to cope with higher loads, heavier dishes and stronger winds;
I'm sorry if this sounds stupid, but the reason for my thread on the first place was that i didn't understand the difference between the way the 2 different mounts tracked the clarke belt, but i've now realised: it's exactly the same
Actually, thinkin of it, "polar mount" vs "horizon-to-horizon" seems like a quite daft designation, as both setups seem to be polar mounted (ie used the polar axis) and track one horizon to the other - or is the jack/actuator system more limited in ° scope?
Old 25-06-2006   #17
kamaleon's Avatar
.There are also some Diseqc actuators appearing, best of both perhaps
Are you talkin' about let's say a Vbox positioner?
Old 25-06-2006   #18
Lancelot's Avatar
I think what he's saying is that there are/wiil be, jacks/actuators that are diseqc controlled like the SG2100 et al. As opposed to the current crop which are 36V controlled and require a VBox to run them on most modern recievers.
L.
__________________
Old 25-06-2006   #19
Oldgeezer
johnsattuk's Avatar
L.
I do have a SuperJack DiseqC 1.2 actuator that I was going to play with, but went a different route. It works directly off the reciever, no V-Box required.
SuperJack DiSEqC 1.2 actuator, 12v motor 8inch stroke. DARL-1208+
__________________
Oldgeezer
Old 26-06-2006   #20
Unless the actuator is matched perfectly to the polarmount, there will be a limitation on one (or both sides ) of true South.
One problem of standard polarmount designs on walls is that the actuator will stick out the back of the system, and may run into the wall if the bracketry is too small.
Many of the cheaper polarmount designs also restrict the distance of the actuator from the main point of rotation and then accuracy of tracking and positioning is affected, and leads to premature wear of all parts.
I would be very wary of any polarmount that can only use the mini jacks, though I do have one prototype in the garage somewhere that did look the business - will try to get some photos later.
__________________
Old 26-06-2006   #21
Oldgeezer
johnsattuk's Avatar
Would be interested in the design of the prototype, if poss can you show details in close up
__________________
Oldgeezer
Old 28-06-2006   #22
My pleasure
__________________
Old 28-06-2006   #23
And the others
__________________
Old 28-06-2006   #24
Oldgeezer
johnsattuk's Avatar
Thanks,
Nice solid looking mount, strong bracket and pivot for the jack, adjustments easy to see and get at. Would take a DiSEqC actuator nicely.
Getting bad attachment message on 3rd piccy.
__________________
Oldgeezer
Old 28-06-2006   #25
kamaleon's Avatar
Mighty goodness!
