Hardware Advice | |
| Member Join Date: 06-05-2006 Location: West Mids
My System: None and moment |
I am after some advice, I have decided to purchase 2 technomates 1500CI+ units and was wondering if anybody could recommend a 90cm dish/motor/twin lnb combination. My main objective is a combination that works well together and is easy to put together. Thanks in advance | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | A motorised system running two receivers has certain disadvantages, primarily that you can only watch one satellite at a time and secondarily, that only one receiver can control the motor.
__________________ | |||
