Help with Atlantic bird 3
Thread Tools Display Modes
Old 26-06-2006   #1
My System: Zone 2 60cm dish,Technomate 7750 2VA 2CI,Sky digibox & Zone1 dish.
I am currently trying to set up my tm7750 to receive Atlantic bird 3, I am only interested in receiving France 2/3/5 on 11591 v 20000.
I do not seem to be able to pick this frequency up,I can pick up the non FTA France 2/3/5,but cant get the FTA. Any ideas as to why I seem not to be able to get 11591V s/r 20000 ,but can receive other channels from Atlantic bird?
Scuttya
scuttya is offline   Reply With Quote
Old 26-06-2006   #2
rolfw's Avatar
What can you actually receive on AB3 and are you sure that you are spot on the satellite??
__________________
Rolf
Donate
Old 26-06-2006   #3
I seem to be able to pick up Pink and quite a few others,I did get ARTE ,but this was a little pixely.When it says you have to have clear sky,where do you draw the line as far as the horizon goes.i have 3 dish sizes I could try,45cm,60cm & 80cm, i am currently using the 80cm.
Old 26-06-2006   #4
rolfw's Avatar
An 80cm should be fine for certainly the Southern half of the UK, you also have to make sure that there is practically no skew on the LNB. If you have a DECT phone near the receiver, unplug it, as they have been known to affect satellite reception on transponders where the IF is similar.
__________________
Rolf
Donate
Old 27-06-2006   #5
Regarding the actual position in the sky of the satellite, I guess this would be at about 31 degrees above the horizon, is this correct? if so I may have to put the dish higher as I have some obsticles (in the distance) in the line of sight. Is digital satellite like digital terrestrial tv ? I have come across some channels not being picked up due to misalignment of a normal digital aerial, is this the case also with satellite ?
Regards
Scuttya
Old 27-06-2006   #6
rolfw's Avatar
More so with satellite, it needs to have perfect line of sight and nothing whatsoever in the way.
__________________
Rolf
Donate
Old 27-06-2006   #7
so , if I imagine my eyes are in the middle of the dish I should see nothing but clear (Blue!!) Sky ?
I do live down a slight hill and south is up the hill, this may be the problem,I think I ma need to get a longer ladder and put the dish up on top of the house !
The elevation of the dish is about 31 degrees currently, i am sure this about correct for cambridgeshire (I think the precise elevation is 30.31 degrees).
Thanks for your help ,the forum is a great place for newbies like me,I am learning slowly.
Regards
Scuttya
Old 27-06-2006   #8
rolfw's Avatar
As a rule of thumb, the elevation for that satellite is just over 1 in 2, so and easy way to see if you have approximate line of sight, is to measure the height of the bottom of your dish, then put a pole on the ground 1m higher approximately 2 metres away in the direction of the satellite. If you can see clear sky whilst looking from under the dish, but above the pole, then you should be able to see the satellite.
__________________
Rolf
Donate
Old 28-06-2006   #9
My System: 28e, 19e, 13e, 30w
I've got a 'Porty' dish (35-42cm *ish*) and it can easily pick up the France Television transponder on 5w. I'm located in Hampshire and have had no problems getting a signal through double glazing!
Skip Channel is offline   Reply With Quote
[IMG] code is Off
Forum Jump
