No Audio/Video on 16E | |
| Emperor born of a peasant Join Date: 31-05-2006 Location: Hull/East Yorkshire - Lat 53.769, Long -0.369
My System: Technomate 1500CI+ with Gilbertini 1m dish, MTI quad lnb, Dragon cam Cerebro card, Dynamite programmer, Skystar2, Full Bouquet Art Sports |
I have a strange problem with 16E, when selecting free channels such as my music the level is 97% & quality 82% but the screen is black with the error message 'No Audio/Video' I have a 90cm Dish with TM1500CI+ & 0.2 lnb. Any advice greatly appreciated, I want to get a Digitalalb card but obviously I need to sort this issue first. | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You may perhaps need to enter the pids manually, playing fine here on an 80cm dish, but i am much further South than you.
__________________ | |||
| | #3 | |||
How do I do that? | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Go into edit channels, there should be a facility to do it there. You will find what they are on Lyngsat.com
| | #5 | ||
| Guest
Posts: n/a
| how many channels show an error,is it just a few here and there?or a large number?i found the technomate 1500 signal indicator unreliable half the time,i could be tuned into perfectly to hotbird and it says perfect signal for hispasat at 30 degrees or something odd like that on a monoblock lnb. Ive now bought a proper lcd signal indicator which gives the exact same readings as my humax hd receiver,the technomate is giving readings double what the humax and signal indicator device are giving.if the humax says 50% strength the technomate will say 100% | ||
| | #6 | ||
My System: Technomate 1500CI+ with Gilbertini 1m dish, MTI quad lnb, Dragon cam Cerebro card, Dynamite programmer, Skystar2, Full Bouquet Art Sports | Its just 16E beintot. All the FTA channels say the same, but I can tune in to every other satellite with no problems. | ||
| | #7 | ||
| Are you sure the dish is pointing towards 16 East and not another satellite completely ?
__________________ There is a very fine line between "hobby" and "mental illness" | ||
